truck accesories with LS1 intake?
I couldnt find anybody to make me some 1.5 spacers so I just used two 3/4 inch ones on each side.
Dirty Dingo acted like I was crazy when I asked for 1.5 spacers & when I asked them to make a set they said it would be a couple hundred $ .
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Used to be on ebay all the time (expired link below). I think Wegner still makes them though.
http://www.ebay.com/itm/2-LS1-Water-...sories&vxp=mtr
ZQ8LS1, thought you were looking for regular spacers for the accessory brackets not the pump. If your trying to space the pump then I agree with 99vettefrc, swap the truck pulley onto the LS1 pump. Drill and tap the pulleys and use a steering wheel puller to remove the pulleys. Then stick the truck pulley in your outdoor grill and get it hot, 400 degrees or more for 20 minutes. Then quickly install it onto the pump. Be certain you know how far to install it first as you won't have much time for adjustment.
If you have access to a press, you could probably remove the rear cover(bolt on style) to press the pulley in place. It's pretty easy to swap so forget about the pump spacers.
