Electromotive Tec 2 and LS1 HELP
I will be running a tecIII on my ls1. I don't believe you can use the stock pickup wheel for the crank signal, you may be able to use the stock cam signal for a full seq set up. I would contact electromotive to make sure.
I had to have a bracket made up to mount the trigger wheel to the stock pully. You also have to get the stock pully keyed and the crank pined to keep the pully from slipping.
Larger image
Larger image
Larger imagemark
Larger image
Larger image
Larger imagemark
IAC - located on the throttel body
TPS - located on the throttel body
water temp - located on the drivers side of the head
I did hook up one of the stock knock sensors but the tuner didn't use it so I don't know if the tec can read the signal or not. I have a wide band, plenty of fuel + meth so I am not worried.
Not 100% but I think I got the plug ends from Speartech.
I am using the following electromtive supplied sensors
3 bar map sensor
air intake temp sensor
crank trigger sensor
For the crank trigger wheel I had a bracket made to hold it. See above pictures. For the cranks sensor I built a bracket that attaches to the bracket I made to hold the alternator.
I run a phased sequential set up so I didn't bother hooking into the cam sensor. The tec unit may be able to read the stock gm cam sensor. I would ask electromotive about that. If you find out let me know maybe I'll switch to full sequentail.
mark
