1968 Chevelle LQ4 Build
What it looked like the day I bought
Some of the metal work done
What it looked like the day I brought it home from the body shop
Currently I've been gathering parts for the swap. I was able to get a long block LQ4/80E for pretty cheap. I was also able to find a good deal on a f-body oil pan, Dirty Dingo slider mounts and I'm still undecided on whether I should use the Doug or Hooker swap headers. Right now I'm looking for an accessory drive, wire harness/pcm and a few other parts.
I plan to redo all the suspension with UMI parts starting with the rear and working my way up front.
As of right now the car is sitting but hopefully I can get this project started soon. Any and all info/suggestions is helpful thanks in advance.
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
You will really enjoy the LS. Driveability is so improved, and when you tackle the suspension and brakes it will be like driving a new car.
Are you using the horse shoe shifter? I don't recall if that was an option for that year but if you do shiftworks has the stuff to update your console. If you are still working on this next summer I could probably sell you my setup when I swap to a stick.
. I would appreciate any photos and part # you can provide. ThanxAre you using the horse shoe shifter? I don't recall if that was an option for that year but if you do shiftworks has the stuff to update your console. If you are still working on this next summer I could probably sell you my setup when I swap to a stick.
Frame mounts #3379 www.carpartsdiscount.com
Headers Dougs
Engine adapters Dougs SK100
Motor mounts Energy Suspension 3-1117G
If you are using truck accessory mounts you will most likely need to change PS pulley to Dorman 300-123.
Don't waste time with the truck pan, it wont work out well. I used Canton 13-274 with pickup 13-275 and filter mount 22-631.
There are a host of others as well that won't require cutting the k-member.
I can supply pictures if you are interested.
I also used all UMI suspension components as well as QA1 coil overs at all 4 corners. I prototyped new mounts relocating the rear shocks to the forward side of the axle. I can probably find the patterns if you are going that far.
Also I'm still looking for an accessory drive the wrecking yard fell thru. Because I'm still fairly new I'm unable to post to the Classified section so if anybody happens to have an accessory drive to sale please PM me. Thanks
http://www.nastyperformance.com/shop...fuel-line-kit/
I got the setup for $200 a few months ago
