vss for a ford t5?
Old Sep 25, 2012 | 08:40 AM
Gregamuffin's Avatar
Default vss for a ford t5?
hey guys,
still can't get my foxbody swap running right, it wants to stall almost immediately and i can't get the idle right still. there are a few things i still need to check (I'm away from my car at school) but I just remembered i never hooked up the VSS. the wiring harness i got from speedway motors has provisions for a wire to be crimped in for the VSS. might this cause my poor idle issue? and i've heard a lot about Dakota Digital, but which pass thru vss do i need? im running a FORD t5 behind my ls1 and I'm still using the cable driven speedometer. thanks guys
Old Sep 25, 2012 | 08:52 AM
i r teh noobz's Avatar
A bad VSS signal should cause stalling at stops and such. If it won't idle at all I'd look at other things first.
Old Sep 25, 2012 | 08:59 AM
Ok but I've been reading they're a good thing to have either way. So if I'd like to get one in order to rule it out as a problem and for the benefit of having one which one would it be?
Old Sep 26, 2012 | 08:54 AM
Anyone?
Old Sep 26, 2012 | 12:16 PM
gagliano7's Avatar
I don't have my vss hooked up to my 1992 chevy truck 5 speed manual truck tranny 5.3 swap and truck runs great and idles fine.
Old Sep 26, 2012 | 12:54 PM
Again, I appreciate your response but it really doesn't answer my question. At this point I'd just like to buy the Vss sensor because it would rule it out as a problem especially because I don't know if the person who flashed my computer deleted it. I'd just like to know WHICH vss I need to use with my ford t5
Old Sep 26, 2012 | 01:00 PM
be good's Avatar
if you have a stock ecu you will need to get the vss turned off. otherwise it will start, run for about half a sec, and shut it'self off. take the ecu to someone with hp tuners and get it shut off.
Old Sep 26, 2012 | 06:19 PM
pdsq98gt's Avatar
I think you're getting vats confused with vss. If you get a good tune, it probably won't stall as much. Even without the vss. However, with a vss and tune it'll be even better since you'd have idle tables in effect.
Old Sep 26, 2012 | 06:49 PM
Ya exactly vats has been tuned out. If I send my computer to frost to have a mail order tune should that help me out?
Old Sep 26, 2012 | 09:21 PM
pdsq98gt's Avatar
He may be able to help you out depending on your mods, but a custom tune is the best way to go.
