converting my 68 to daily driver
If your looking for a cheap option keep the truck manifolds. I've seen most use Hooker or Doug's for headers. If you do plan to use any brands set of headers its is probably your best bet to also use there adapters too.
I personally used the Dirty Dingo Alternator/PS Pump relocation bracket in my setup but have read many threads where people have easily mod the truck bracket with success.
Your also going to need to modify the harness unless you plan to buy an aftermarket harness.
Good luck!
I dont know the best parts to fit your body, but you can even make your own motor mount plates (search for dimensions). Car exhaust manifolds can be cheap if you look, and you can buy new (China) stainless Camaro shorty headers ~$200.00. If you are comfortable doing wiring and have basic electrical knowledge, the truck harness is easily modified. It will take a few hours of your time - LT1swap.com. PSI is a sponsor here and has a nice harness. I would try to find a late plastic fuel tank that fits and use an internal pump.
Good Luck
Try to create a plan and stick with it the more you change the more expensive it becomes.
some parts i will be getting to help with the swap:
Doug's Headers Engine Swap Motor Mount Kits SK100 $74
Energy Suspension Motor Mounts/Motor Mount Inserts 3-1117G $37
Dorman Power Steering Pulleys 300-123 $25
Canton Racing Drag Racing Wet Sump Oil Pans 13-274 $312
Canton Racing Oil Pan Pickups 13-275 $88
Canton Racing Oil Filter Mounts 22-631 $154
as for headers, i dont know what i should be looking for. 98 camaro? is there parts anywhere that are cheaper? this thing adds up like crazy $690
If you haven't not already purchase one you're also going to need to purchase an idler pulley relocation bracket or make one yourself.
If you have not already bought the Canton pan you may want to look into the Autokraft or the Holley LS swap pan at $350 you get a complete kit. I've heard similar things about the Autokraft pan.
http://www.ebay.com/itm/98-02-CAMARO...ht_3776wt_1014
98-02 f-body?
some info i found on chevelles forum
http://www.chevelles.com/forums/show...s+swap+headers
https://ls1tech.com/forums/conversio...rs-option.html
https://ls1tech.com/forums/conversio...y-headers.html
Those EBay headers dont look bad and for the price if you are willing to make them work I don't see where there would be a problem. All the threads I've read have said that you will have to mod the collector on the driver side.
Its a big project, but its not hard. Just take it one wire at a time so you don't get lost and overwhelmed.
Holly Oil Pan
Hedman Husler 45540
Trans Dapt 4595
Dorman Products 300-123
and started the mod on my truck harness. got confused on some parts. i unpinned the wires and followed them up to the sensors. do i cut of the ground wires on them as well, cause theyre no longer needed? few examples:
also, i cut and labeled the orange and pink wires from the C2 fuse block. im kind of worried cause 1 pink wire (E2- fused ignition positive voltage- transmission, PCM) didnt lead anywhere after i cut it.
this one is attatched to the harness but the pink wire. im thinking this is a pink wire that lead to the lose pink wire (E2)
all the wires here were cut, but the ground. do i cut the ground and discard?
thanks guys
1. You can go the inline fuel route that many have done successfully. One draw back is that because the pump is external they do have a chance of overheating a dying out sooner then normal life expectancy. Also some have complained of fuel starvation.
2. I spoke of the b-body tank option. It seems to be the most economical choice. You will have to cut a hole into your trunk pan for tank pump clearance and trim the frame railing as the pump is wider than the stock tank.
3. You can use the original tank and mod it with a Tanks Inc, Aeromotive or 2010+ GM Camaro in tank pump. It takes some welding and cutting to the old tank but has been proven to work.
4. You can buy a tank designed for EFI. I've seen them go for $350-$1800+.
