Another 89 Mustang Coupe LS Swap
Very good info on the power steering. I was thinking of just taking it to a local hydraulic shop, but a bolt on solution is nice.
I am right there with you on trying to get an answer. When I am trying to get in touch for 2 days and never get a call back I have a problem with that. Then I got some misinformation about compatibility from them as well....maybe they misunderstood, or just didn't listen to what I was asking, but regardless it is now costing me time and money. Seemed like it was a bother to speak to me on the phone. No tracking info on the package I ordered from them....maybe good products, but lousy service.
I would just start with a stock 4L80E for like $500 at most places around here and throw in a shift kit for now. If you need more you can always get it built later, but at least you have a good base that can handle whatever you throw at it NA wise and probably even handle some nitrous. The 4L60E gets expensive in a hurry to try to make one last. Jake's builds those too, but to hold the same power you will more than likely spend a good bit more than a 4L80.
I got the front suspension and rear finished yesterday. I still have to swap over the fuel lines and battery cable/box. I bought an a1000 and boost sensitive regulator so I'll need a few fittings to get the fuel system finished up. Ive been working 7/12's for the last few weeks. By the time I get off I only get about an hour of daylight to mess with it. I put the coil over and caster camber plates on the front last night.
![](http://i788.photobucket.com/albums/yy170/whippdcobra/2012-10-12_18-43-11_23.jpg)
#32
I'm in the game planning stags of a Lsx fox project, everything I've read on here & yellowbullet team-z is top notch, I'm curious as why your not considering team-z headers? They say their the best fitting with their k
#38
Still waiting to get some free time so I can drop it off to have some front frame rail work done. In the meantine, I'm gather parts lol.
I ended up finding a 2001 complete pullout 5.3L and 4L60e, with the wiring harness, computer, all the front accessories etc, from another member. A friend of mine will be up his way this weekend and picking it up for me. A couple of pics the seller snapped with his phone.
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/LS%20Motor/motor.jpg)
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/LS%20Motor/motor-1.jpg)
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/LS%20Motor/trans.jpg)
Also scored a good deal on a set of Team-Z controls arms
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/controlarms.jpg)
While I have the front end apart, I wanted to go ahead and upgrade the brakes as well. Picked up a set of 95 Mustang Spindles and rotors, along with a pair of PBR aluminum dual pistons calipers. They will all be cleaned and painted before they are installed.
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/brakes.jpg)
Still have the Strange 10 way adjustable struts, coil-over kit, and rear Strange 10 ways to put on, along with a set of Eibach drag springs for the rear
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/Strange.jpg)
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/Rear%20Suspension/springs.jpg)
Picked up a cheap LS1 Intake
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/intake.jpg)
Which actually brings be to a question. Any particular aftermarket fuel rails better than the rest? I see them on Ebay all day for less than $100/set. Was curious if those were any good or not? I'll be running them with the rest of the fuel system I already have most of.
Manafuel pump and Magnafuel dual fuel pump relay setup.
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/Fuel%20System/parts.jpg)
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/Fuel%20System/pump.jpg)
Filters
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/Fuel%20System/12304and12301Filters.jpg)
Aeromotive (from Fast system) 13101 regulator
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/Fuel%20System/Aeromotive13101.jpg)
Aeromotive (from Fast system) Y-Block
![](http://i210.photobucket.com/albums/bb241/billyndonna/00%20Mustang%20Coupe/Fuel%20System/Aeromotive15620.jpg)
Also already has in tank pick-up with AN fittings, and braided line all the way to the motor and back to the tank.
Filters
#40
Lookin good, man!!...I was also wondering about the El Cheapo Ebay rails too....I talked to a couple friends...They simply said, "You get what you pay for...They may leak"...hmmmmm....They told me that the stock rails will handle 800hp or more...Dunno how true that is....
