Custom Hose? Possible?
Old Oct 11, 2012 | 11:06 PM
badazz81z28's Avatar
Does this make sense? Oh...The 150 degree or "50 degree" trunk is ( 9 1/2" )
Old Oct 11, 2012 | 11:18 PM
454ragtop's Avatar
The van upper hose I posted earlier is a Napa 7092, 87-88 chev Van 5.3.
HTH, Jim
Old Oct 11, 2012 | 11:24 PM
Maybe better here
Old Oct 11, 2012 | 11:26 PM
Old Oct 12, 2012 | 07:46 AM
1976CamaroGuy's Avatar
I learned a tip on finding a hose from a show one time where they were installing a LT1 in an el camino.
With the engine and radiator in place, take a wire clothes hanger apart and bend it to the shape that you need the hose to be, every angle and the exact length.
Take the bent hanger to your local auto parts supply store and match up the hanger to a hose that is the closest to the diameter, shape and length you need.
If you can't find a single hose in the shape and length, look at combining two hoses with the shape and length you need based on the hanger shape.
Problem solved
Old Oct 12, 2012 | 07:48 AM
and for a sharp 90 degree turn, I think you can get these hose benders
Old Oct 12, 2012 | 10:46 AM
gMAG's Avatar
Problem solved
This is the way to go, imo, although I'm not keen on splicing hoses together.
With a drawing, a minor bend not indicated on the drawing can make the difference between a fit or not.
Old Oct 12, 2012 | 11:18 PM
I tried the auto part store mix and match...No luck finding anything I could splice together. My drawing is pretty straight forward. No funny bends...
Old Oct 17, 2013 | 12:02 PM
sjaroslo's Avatar
Originally Posted by Pop N Wood
Dayco has an online guide that lets you look at every shape and size hose they make
http://www.accessdayco.com/Dimensional.aspx
Wow, I wish Gates had a service similar to this! I'm trying to find a lower hose that would work and this would certainly narrow down some choices. I just downloaded the Dayco app to my iPad that has the same dimensional lookup service. Really nice!
Old Oct 17, 2013 | 02:14 PM
Pop N Wood's Avatar
They do. I use to have a link for a similar app from Gates, but for some reason the link went dead. I was searching for the Gates app when I found the dayco one.
If you find a dayco part you should be able to cross reference the gates part.
Old Oct 18, 2013 | 03:12 PM
19wagon63's Avatar
try a cut to length aluminum hose from summit. They are bendable and stay where you bend them. Good luck
