Won't stay running
Old Oct 14, 2012 | 08:57 PM
wazzubob's Avatar
Default Won't stay running
2004 LQ4 with a flashed PCM and stand alone harness. The engine cranks, and fires off quickly. It will run for a few seconds, and die. My tuner says VATS has been shut off.
We've confirmed the following:
-Fuel pressure at rail 58psi
-Scangauge reads voltage, air intake temp, water temp, engine RPM, ignition timing during crank and the first few seconds until it dies
-No codes found
-Engine will not continue to run even when carb start is used
-Getting spark at the plug during crank and first few seconds until it dies
-CEL is working during run/crank key positions
The factory oil pressure sensor is NOT plugged in or being used. I was told the PCM does not care about this signal.
Engine still dies with one of the following disconnected (one at a time)
-O2
-MAF
-Coolant Temp
-MAP
What do you guys think? I really feel like the PCM is shutting it down for some reason.
Old Oct 14, 2012 | 09:11 PM
gMAG's Avatar
There are cases of VATS appearing to be turned off, when in fact, VATS is still operating.
Old Oct 14, 2012 | 09:14 PM
wazzubob's Avatar
So I need to send my PCM back to the tuner, or find someone local (seattle)?
Old Oct 14, 2012 | 09:24 PM
Rick Speed's Avatar
Yeah verify it.
Old Oct 14, 2012 | 09:33 PM
gMAG's Avatar
Here's a good reference thread ...
https://ls1tech.com/forums/conversio...mediately.html
You can skip to post #44, if you want.
Post #10
https://ls1tech.com/forums/conversio...tup-issue.html
Old Oct 14, 2012 | 09:52 PM
wazzubob's Avatar
It's a 2004 Van motor, you think I need to check the 'steering column lock' setting on my PCM?
Old Oct 14, 2012 | 09:56 PM
wazzubob's Avatar
Do you guys think having no oil pressure sensor is causing my issues?
Old Oct 14, 2012 | 10:01 PM
lizeec's Avatar
Sounds like the vats delete did not take, and the oil pressure switch has nothing to do with your problem, the PCM does not need to see anything from the oil pressure switch. If you can find someone local with HP Tuners they can verify or try the vats delete.
Old Oct 14, 2012 | 10:05 PM
spotmy4's Avatar
This happend to my swap, sent my ecu back to the tuner.
I didn't change anything reinstalled when i got it back started right up.
Old Oct 15, 2012 | 11:26 AM
gMAG's Avatar
bob..I'm just supplying links that may give you a lead, one way or the other.
I wish I could give you definite info, but sometimes these issues will run you around in circles until it's resolved.
It may be as simple as turning VATS on & off once again.
Old Oct 16, 2012 | 12:16 AM
wazzubob's Avatar
We got it running tonight! Not sure why, but it took some carb start into the intake to get it running, but it eventually found an idle and ran unassisted. The MAF is still suspect, but at least it runs.
Old Oct 16, 2012 | 08:43 AM
gMAG's Avatar
Nice job.
Congratulations!
Old Oct 17, 2012 | 08:24 AM
lizeec's Avatar
-No codes found
-Engine will not continue to run even when carb start is used-Getting spark at the plug during crank and first few seconds until it dies
-O2
-MAF
-Coolant Temp
-MAP
So which is it?
