Jeep Grand Cherokee steering box swap on a-body
Old 10-28-2012, 10:23 AM
1964SS's Avatar
Default Jeep Grand Cherokee steering box swap on a-body
I've been reading up on this swap and will be picking a box up this week to do the swap. I read that the 93-98 steering box will work. Does it have to be from a 2wd or 4wd jeep? or are the boxes the same? I can't find this info anywhere.
Thanks!
Old 10-28-2012, 10:38 AM
LS1 pwrd NOVA's Avatar
If I recall correctly, its from a 2wd. Now if u don't know this, there are a two or more different types. Quick ratio and a regular ratio box. Which are you looking at getting? Pull up team chevelle or aka chevelle.com all kinds of A body info is there. Hope this helps
Old 10-28-2012, 11:45 AM
CutLS's Avatar
I never knew there were two different types. Any way of telling by the part numbers or look?
Old 10-28-2012, 12:17 PM
garys 68's Avatar
When I was researching the swap for my 72 442 I only found 1 steering gear for 93-98 GC from Rock auto, and the local parts suppliers. I picked a used one up through car-part.com.
It made a huge difference over the old one.
Old 10-28-2012, 02:13 PM
Received 3,512 Likes on 2,164 Posts
I purchased one just a month ago or so. I struggled to find the info needed for this swap (the search function here is great if you have a couple of full days to kill), so I ended up buying the wrong box at first.
The box that you need is a jeep Grand Cherokee, 98' model, two or four wheel drive. They are the same box. You can look for a 93-98 box, as they are the same. I bought mine from a buddy who owns a yard, and I found a low mile 98' for $75.00. I got the steering shaft with it so I won't need a different rag joint. I will adapt the jeep shaft, which uses a universal joint, instead of a rag joint.
Attached Thumbnails Jeep Grand Cherokee steering box swap on a-body-image.jpg
Old 10-28-2012, 08:16 PM
So how do you know if you have the quick ratio steering box?
Old 10-28-2012, 09:51 PM
The jeep boxes are 12.75:1 ratio.
Old 10-28-2012, 09:55 PM
1964SS's Avatar
I want the quick ratio 12.7:1 box for sure. From the research I did today The following boxes are what I need.
1992.5-1993 Alpha code AL or BT
1994 Alpha code AL, BT, or PD
1995 Alpha code JH
1996 Alpha code KD
1997-1998 Alpha code WK or BT
Anyone know where the alpha code is on the boxes? I will be looking for one this week.
Old 10-28-2012, 10:46 PM
garys 68's Avatar
93-98 GC steering box, $40-50 used, $120 new Autozone. Never found any 2wd/4wd difference or any other ratio. Original A body was about 16:1 (felt like driving an old school bus),GC is about 12.7:1, huge difference.
Dorman rag joint 31011, $40 Autozone
85 monte carlo high pressure hose $14 Autozone
You reuse the A body pitman arm.
In terms of a real difference, best $100 I spent on any car.
Old 10-29-2012, 06:14 AM
oldgoat69's Avatar
Looks like the code is on the paper tag, look at the last photo. KD
Old 10-29-2012, 10:46 AM
lizeec's Avatar
If you buy new from a parts store they usually want a core charge of between $75.00-$100.00 if you dont have a core to turn in. If you have your old one you can use it for the core exchange as they look identical on the outside, the only noticeable difference is the o-ring or flare female fittings, but I guarantee 99.9% of the dweebs at most parts store don't know what to look for.
Old 10-29-2012, 10:51 AM
1964SS's Avatar
Sweet! easy enough to identify. Thanks for catching that.
Old 10-29-2012, 11:30 AM
garys 68's Avatar
Hell, I took the pic and never looked at the tag. Good catch...and mine was a 96.
Old 10-29-2012, 02:06 PM
pairof69s's Avatar
this works for the 1st gen F-body's too right....?
Old 10-29-2012, 02:54 PM
1964SS's Avatar
No I don't believe it will work for the camaro.
Old 10-29-2012, 04:01 PM
1981TA's Avatar
So is the steering box from a 1980-1981 Trans Am--and it even connects to a later model PS pump using a stock C5 high pressure hose.
Old 10-29-2012, 09:34 PM
flywheel's Avatar
ive used several of the jeep boxes, 92-98 GRAND Cherekees 2 or 4 wd...need a rag joint from a mid 80 3/4 ton chevy trk, and it uses metric hoses. Or you can buy some inserts to be able to use the chevellle hoses...I get them from a junk yard for $75... well worth it....
Old 10-29-2012, 11:34 PM
1964SS's Avatar
I picked a box up today from a 1998 Jeep grand cherokee. Alpha code BT. Hoping to have the car ready for a show this weekend.
Old 11-18-2015, 02:27 PM
Seeker1056's Avatar
Default GC box differnces??
interstingly enough - I go to my pick a part and the GC boxes are listed as 93-95, 96 only and 97-98
so which one - definitely not the 96 - it is some soft steer thing
thanks
Old 11-18-2015, 02:56 PM
Project GatTagO's Avatar
Received 1,441 Likes on 909 Posts
Tons of info here:
http://www.chevelles.com/forums/showthread.php?t=334534
Andrew
Quick Reply: Jeep Grand Cherokee steering box swap on a-body
