OEM straight thermostat housing!!!!
I found a GM thermostat housing that's almost straight and should work with my swap. No more having to find someone who can weld aluminum to modify the stock housing or paying $95 for the S&P one. I believe it's from an I6 Trailblazer. It's got the part # 12567750. It needs to be slightly midified to work, but it's nothing that you can't do in 5 minutes with a file and a cutoff wheel. One of the bolt holes needed to be slotted and the side of the part that that goes into the waterpump needs to filed down a little. You can see where I filed it down in the first pic. The last pic shows it in the car before I cut down the elbow part. I cut it on the black line that you can see in the picture.
Hopefully this helps some people out.
-Matt
-Matt
I looked up that part number on GMPartsDirect and it didn't come up with anything. If someone has access to the dealership computer and can see if there's a new number, that would help out anyone who needs one.
Ok. We'll have to look up that number then. The guy who I got it from wasn't sure, but that's what he thought it was from. Guess not. I'll e-mail the number to my dealership parts guy and see what he can come up with.
