Lt1/LS1 T56 Swap.... Why?
Old 10-30-2012, 04:24 PM
Thunderkyss's Avatar
Default Lt1/LS1 T56 Swap.... Why?
I know there are a few parts that need to be changed on the LSx engines if you want to use an older T56.
I don't know why.
Here is a guy who bolted a T10 an LSx, why can't the same "procedure" be done for an older T56?
Old 10-30-2012, 04:45 PM
brewster240's Avatar
you can bolt the lt1 t56, but the ls t56 is generally better and has a better clutch/hydraullics design.
Old 10-30-2012, 08:45 PM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
Input shaft length/clutch styles are completely different. That's the primary issue. The Clutch on a LTx motor is unique as it pulls on the pressure plate instead of pushes on it; this is why it's not as simple as a T-10, M2x, Richmond, etc swap on a LS motor.
Old 10-30-2012, 10:07 PM
Kory 88Iroc Lt1's Avatar
The lt1 uses a 153 tooth flywheel. The ls1, and alot of sbc style trans use a 168 tooth flywheel. THe larger flywheel will not fit in the lt1 bell. you could get a custom flywheel, but they are expensive. Cheaper to convert or sell an lt1 trans and buy an ls trans.
jmo,
Kory
Old 10-30-2012, 11:11 PM
jmo,
Kory
So it would probably be easier to put an LSx T56 on a SBC or BBC than an LT1 T56?
Quick Reply: Lt1/LS1 T56 Swap.... Why?
