89 Formula getting 5.3
Old Oct 31, 2012 | 08:50 PM
jay7199's Avatar
Default 89 Formula getting 5.3
Got this car for a steal, Was previously LSX swapped, The motor was pulled and sold... I got it as a roller with the built 4l60E
I have almost everything to get this car back on the road, Making some changes along the way.
Heres some pics, engine bay is getting repainted along with some body panels.
Car was $400
5.3 with unknown milage, $150.. needed 1 piston replaced.
3 sets of heads with double valve springs $200
SLP cam 234/228 .576/.571 113 $150
F-body oil pan found for $20
25% UD pulley with motor mounts i needed $50
Gota use stock 02 F-body manifolds, no headers will work apart from $800 swap headers.
Going to run a stalled auto with 3:73 gears out back.
Budget racing!
Attachment 728420
waxxxx
Attachment 728422
Attachment 728423
Attachment 728424
Attachment 728425
Attachment 728426
Attachment 728427
[/quote]
Old Oct 31, 2012 | 08:51 PM
jay7199's Avatar
GTA taillights.. picked up a intake.. Started to mock up the motor and build the harness.
Old Nov 1, 2012 | 07:53 PM
jay7199's Avatar
Harness is starting to come together, Only things left are ignition, cam/crank, MAP and IAC/TPS
Old Nov 2, 2012 | 07:29 AM
cprmn14's Avatar
subscribed. Good prices on your swap parts!
Old Nov 3, 2012 | 11:48 PM
jay7199's Avatar
I built the coil connectors from scratch from the v6 harness today, Also installed the cam.
As for the connectors, The groove the pigtail uses as a guide had to be made, Depinned the plug and installed wires according.. Had to splice some colors in, I.E one or two wires have a stripe but should be a solid color, So I just spliced in the solid color all the way to the PCM.
Heres some more pics.
Old Nov 12, 2012 | 12:16 AM
jay7199's Avatar
Got the converter, the shortblock reassembled and the engine bay painted.
Still collecting bolts and a few odds and ends, hoping to hear it run this coming weekend.
Old Nov 20, 2012 | 09:24 PM
jay7199's Avatar
Sorry for more cellphone pics, the weekend didn't go at all as planned, so getting home from work at 6 and working on this thing.. leaves little motivation to dig up the nice camera.
These are my heads notthing special.. but will do the trick
Also painted the motor, love this color.. Wish I had used it on my Trans am..oh well.
Old Nov 29, 2012 | 10:01 PM
jay7199's Avatar
Old Nov 29, 2012 | 11:14 PM
Jesse_P's Avatar
Special place in my heart for third gens, nice build so far!
Old Nov 30, 2012 | 11:25 AM
OutlawDrifter's Avatar
try the brp/hedman hustler mids...the price might surprise you. i've been running them on my 6.0l swap'd 91 Z/28.
Old Nov 30, 2012 | 12:14 PM
edrex's Avatar
looking good. What trans are you going to run
Old Nov 30, 2012 | 08:06 PM
jay7199's Avatar
header part number HED-45000?
It has a 4l60E thats been rebuilt, supposed too be like a stage 2, half the receipt from the trans is ripped off so i can't see the parts list.
And a Vig 3200 stall
Old Dec 2, 2012 | 09:20 PM
jay7199's Avatar
Finnished getting the motor bollted down, had to slot the motor mounts -_- Got the trans hooked up, Lost my drive shaft when I bought the car... ops!
Wires tucked up around the motor, still some cleanup where the PCM is to be done, most of that mess is for the transmission.
Don't think many people will like the paint, But I do!
Old Dec 3, 2012 | 09:46 AM
mine are the coated mids, go to brp muscle rods website(they sell them cheaper than anyone else), they are affordable, and the fit and finish is awesome.
Old Dec 3, 2012 | 08:11 PM
jay7199's Avatar
ok here are some HD pics, I didn't get to start it today.. Lost my header bolts! But this shows how the wiring harness ended up, its not completely done I still have some looming to do.. Im pleased with the outcome.
Old Dec 4, 2012 | 01:02 AM
Redbull87's Avatar
Thats an odd color but it somehow works with the white car and black engine bay.Nice work..the wiring is what took me the longest to do..for tucking and running them in a nice tight fashion.Should be a nice lil sleeper formy.
Old Dec 4, 2012 | 06:24 AM
ramairetransam's Avatar
sweet, i always wanted to do this swap to my 85
Old Dec 5, 2012 | 09:38 PM
jay7199's Avatar
Well she is sputtering, I guess im having a vats issue.. cranking with no start, pulled plugs and they are dry.. Checked for compression as well, 160psi so i added some starter fluid and its sputtering, so I need to figure out why the injectors won't click away!
I can only assume my harness is working out.
Old Dec 6, 2012 | 09:11 AM
is vats tuned out of your computer? also, did you wire around it on your car? quick and easy to do, its behind the driverside kick panel.
Old Dec 6, 2012 | 10:00 AM
jay7199's Avatar
How do you wire around it? Also I am not sure if vats is Tuned out or not, this computer was previously in the car on it's old lq9 setup so I can only assumed the tuned it out or found a walk around.
