Newbie with questions
Old Nov 29, 2012 | 06:17 PM
abc04b's Avatar
Default Newbie with questions
I am restoring a 1970 Chevy Nova and just bought a LS3 for it. I need some help with a radiator now. Anyone have any recommendations on a radiator and should I get one with electric fans or just get fan seperate. I have read threads about making sure there is enough room without touching the engine. Need help.
ABC
Old Nov 29, 2012 | 06:33 PM
oldgoat69's Avatar
Tons of options out there. Look at the first gen Camaro LS swap radiators and add the dual fans from a 4th gen F body. The fans are quiet and work very well. Easy to adapt to your PCM and wiring harness.
Old Nov 29, 2012 | 06:42 PM
bczee's Avatar
I was able to fit both the 4th gen Radiator and fan setup with a little modification in my 71 Nova.
But yeah.. there are way to many radiator and fans setup to try, some betther than others. You can spend a Few hundred or into the Thousands for a name brand setup... check Ebay, Summit and Jegs for 1st gen F-body and 3rd gen X-body setups.
BC
