Opinions on radiator
Old Dec 1, 2012 | 10:51 PM
GTS78TA's Avatar
Default Opinions on radiator
Whats the best radiator for LSX swap in a 78 T/A. Any opinion would be appreciated.
Old Dec 1, 2012 | 11:09 PM
LS1Bandit's Avatar
I'm not sure I can say what's best but I used a summit radiator in my 78 ta ls1 swap. I've had no complaints or issues.
Old Dec 2, 2012 | 05:50 PM
2nd Gen Fl 'bird's Avatar
I'm using a 2000 f-body radiator. It will sit directly in the same vertical position as the factory style using the factory LS1 fans. I feel this saves headache on the "how to integrate" something else with the harness and PCM. However, I'm using the factory LS1 upper radiator support that tilts the radiator back like in the 4th gen so I can use the aftermarket lid. Finding a factory radiator/fan combo from a 4th gen should be easy and less money if that's a factor.
Old Dec 2, 2012 | 05:56 PM
GTS78TA's Avatar
Do you think you could come up with some pics, i would like to see that setup.
Old Dec 4, 2012 | 11:12 AM
I have a mock up pick somewhere. Bear with me, I'll find it.
Old Dec 4, 2012 | 02:53 PM
the_merv's Avatar
The LT1 Fbody Rad is thicker and works better IMO..I use them.
Old Dec 4, 2012 | 06:32 PM
Everything that I've read is that they do have more cooling capacity. Mild motor, Ls style will suffice. The harness that I had made to use the the factory fans along with the PCM controlling it all just made sense and made things easier for me.
