1973 El Camino ls swap
#48
Thanks, glad you like it, and here's the link to the filter/intake setup.
http://www.ebay.com/itm/BLUE-99-04-G...-/320816825536
#49
Also if you run the air filters as far as possible to the left and right you should be able to pull in some cooler air, for more power.
#51
Well first things first, cosmetically this is the 'final product'. Decided to go semi-gloss black for the wheels:
![](http://i1275.photobucket.com/albums/y457/sexygarbageman/DSCF6042_zps37f3e54f.jpg)
![](http://i1275.photobucket.com/albums/y457/sexygarbageman/DSCF6048_zpsa5470a05.jpg)
Quite a bit has happened with the rest of the car since my last post. Attended LSFest 2013; all was on the trip to Bowling Green, up until about 5am or so, 20 miles-ish from the raceway, hit a major dip in an intersection we had no idea was there, and left a lengthy crack and a few small holes in the oil pan
(note the stock truck oil pan was only 3-4 inches above the ground all the time). Pulled over, shut it off and oil poured out of it like a water fall. Lucky for us the suction of the oil pump when the car is on kept it from leaking while we drove around to find the nearest autoparts place we could. luckily came across an autozone just a few miles from where LSfest was being held, redneck patched it up with some quick dry JB weld, and headed off.
![](http://i1275.photobucket.com/albums/y457/sexygarbageman/DSCF5807_zpsac23019d.jpg)
Sitting at the end of the drag strip.
![](http://i1275.photobucket.com/albums/y457/sexygarbageman/DSCF5870_zpsc473e5a5.jpg)
Happily our temporary solution worked well enough enjoy the event and to get us home. A few weeks later whie going to fill up on gas, hit yet another dip which did the oil pan in completely. Since then the engine and trans was removed to replace the stock pan with a Holly pan several inches shorter than the stock pan, sits high than the engine cross member so there shouldnt be anymore issues with that. Unfortunately in that process discovered the 350 trans bell housing was cracked as well, with loose bolts included. Genius job on our part. Now shes got a 700r4 and running beautifully, eliminated as many leaks as possible, things should be good from here. Time to have some real fun.
![Upyours](https://ls1tech.com/forums/images/smilies2/upyours.gif)
![](http://i1275.photobucket.com/albums/y457/sexygarbageman/DSCF5972_zpscfe3353c.jpg)
#55
Great Job of making a typically ugly car look very nice!! Its great you did all the work yourself also. I was at Ls Fest with my camaro and wish i would of seen this thing so i could of got a closer look at it. Keep up the good work.
#56
#57
Thank you, Thank you. Well hey, I'll be there next year. Hopefully competing; at the least have it in the Show and Shine.
