6.0 foxbody swap
Old 12-08-2012, 06:38 PM
nobox351y's Avatar
Default 6.0 foxbody swap
Got a few questions:
LQ4/glide setup into 84 hatchback.
Are there mechanical ports for water temp, oil pressure?
Best alternator bracket?
Will 94-04 motor mounts with ls conversion plates work with stock location style member? I really dont want to buy another member.
Are the truck coils any different performance wise than the car coils?
Old 12-08-2012, 07:33 PM
WheelsUp84z's Avatar
there are ports on the cyl heads for water temp, and you can drill/tap the adapter above the oil filter for oil pressure.
alt bracket you can use the BMR one or the stock one
they make mounts that bolt to stock k-members
truck coils (ones with the heatsinks on them) supposedly are better, though I have never had any issue with car coils
Old 12-08-2012, 08:15 PM
stangtrader's Avatar
Honestly your best bet is to buy a aje k member unless you have a welder and want to build mounts. The brp mounts and trans crossmember will cost you about the same as a kmember
Old 12-09-2012, 07:50 AM
nobox351y's Avatar
Thanks for the input. It would be great if brp only sold the motor mounts. I dont really want the rest of the stuff. Plus I would like to have solid mounts.
UPR makes the conversion mounts I posted about. http://www.uprproducts.com/mustang-g...unt-solid.html
Is there a way to run the stock tensioner when you are only going to spin the alt? No other accessories will be spun by the belt.
Quick Reply: 6.0 foxbody swap
