DIY steamline help....
I have a few ideas but just can't picture in my mind
Help ???
Leaning toward AN and braided hose combo.
Simple: route to the upper radiator hose. You can buy an adapter or make your own like I did.
Less simple: Dirty Dingo spacers with integral steam line (requires "truck" accessories and "car" water pump).
Complicated: drill and tap the water pump.
I needed to mate two different size hoses so the choice was clear. Jags That Run sells a similar adapter.
1/4" NPT looks awful big as does 1/8" NPT....I keep looking at nitrous lines but the sizes throw me. I understand -4, -6, and all....looking for something smaller I guess ?
I like the stock "spider" setup. Cheap, simple, fits under the manifold.
The trucks use all four ports, the LS6 cars and 2000 -ish up LS1 cars only use the front two. I've been told the preferred setup for performance is all four.
If you want -4 AN fittings, how about this:
The trucks have the back ports blocked and just run the front ports only. LS6 cars also have the rears blocked.
looks like this..
Andy1
1. On my 98 Wrangler LS6 swap I tapped the water pump for the steam line. Has worked fine for over 12 years. Still working. Would I do that again? No. Biggest reason is that if the water pump died in the middle of nowhere I would have to drill and tap the new water pump.
2. Splice in the upper radiator hose. Jags that Run has hose splices that have a NPT port built in.
3. Best IMO is a NPT port plumbed into the upper part of the radiator.
Just my .02.
On the other hand I bought a vacuum filler for cooling systems and its the only way i'll ever do it again.. Just too dang easy..
Just my .02.
The science agrees.
On my last few LS swaps I have used L92"s dressed as LS3's. I like to use the steam cross tube over that has the outlet tube on the right side of the engine. I don't recall if its Camaro, Corvette or truck. Two front ports only. I've never had a problem with over heating.
Then I cut the outlet tube off and drill and tap the hole for 1/8" NPT. Then using a -3 An fitting I use -3 stainless brake line from the engine to the radiator. I get the -3 brake line from the the local stock car parts dealer. They have many different lengths.
I will get pics tonight.
My 6.0 for my truck was built with mainly OEM parts, plus ARP hardware in some spots, oil tube pickup bracket, dual o-ring barbell and 4 corner steam setup plumbed to the upper radiator. All mods that were not really necessary, but provide dependability and reliability in the future.
In my TT build it is a must. It's not about it hasn't happened, it's about when is it going to happen. Better safe than sorry, especially for the minimal cost. .02
