Which wire for VSS / Cable-X?
Old Apr 14, 2004 | 11:32 AM
LS1_FC's Avatar
Default Which wire for VSS / Cable-X?
From what I understand the unit needs the direct output from the VSS. There's a green and purple wires coming out of it on the trans. Which wire is the signal?
I'm assuming i need the direct output and not the one from the ECU.
Old Apr 14, 2004 | 01:32 PM
Mark IXZD 150's Avatar
I'm going to need to know that too.
Old Apr 14, 2004 | 02:27 PM
93LS1RX7's Avatar
Green. Do a search on torquecentral. A bunch of us have been through this pain already.The key is the ground though, like I said look on torquecentral
Old Apr 14, 2004 | 02:35 PM
LS1_FC's Avatar
Searched on here and on torquecentral, every post was "maybe" "dont quote me" on top of that I guess you are supposed to use the ECU VSS signal, any ideas on that color? Green as well maybe?
Old Apr 14, 2004 | 02:48 PM
93LS1RX7's Avatar
Nope the ecu signal is a white wire.
Here:
On the 220 plug:
E (black/white) is grounded
K (Dk Grn/Wht) [pcm red 50] is the Vss out going to the dakota converter
Here is a full LS1 pinout diagram too:
http://www.dxsoftware.com/magnus/wiring.htm
Old Apr 14, 2004 | 03:43 PM
LS1_FC's Avatar
Thanks! you da man!
