LM7 into 80 Malibu Wagon help
Here is my set up
04 LM7 107k
Garret gt 35r with 62 hotside
200-4R 2200 stall
Aeromotive 340 pump
AEM standalone
AEM3.5 bar map
AEM ITS
Ok I know I need an LM7 flexplate, but will my stall bolt to that and where do I get a crank spacer?
I get all kinds of anwers for my intake selection. Some say stick with the truck intake then I see LS6 intake. What stock intake is good with boost?
I also see I can use LSx something springs for 80 bucks, but is the LS6 cam or other better for boost than the stock 5.3 cam.
I want to run an E85 mixture, so will 60lbs injectors be fine?
I see conflicting numbers on what the stock block can hold. I want to strengthen up the block cheaply like using ARP head studs and... To make the stock bottom end stronger to hold as much boost as it can handle.
Sorry for all the ?s I am just not finding definitive anwsers.
Truck intake should be fine. You'll be blowing on it, no need to spend 3-400 on an LS6 intake.
Cheap upgrades would be rod bolts, head studs, nice gaskets, and a good tune. Porting the throttle body (if you use a cable style) might be worth the hour or two it takes to do. Depending on what power you're looking for, I wouldn't go too overboard with the money. 5.3s are cheap to replace if you blow it up.
all this stuff thats swaps over and can be used is confusing as heck. I've just been bookmarking stuff as i run across it so i dont forget.
As far as the intake. If the truck will fit under the hood run it. If you want it to look nicer get the ls6.
Good luck
Good luck
Where can I get a bigger drive by wire TB for the truck mani? I plan on getting a pedal set and harness for this TB.
So far the build has been still moving, but slowly. Can't seem to get all the parts for cheap enough. I got a ford 9in posi 4:11 gears, so got the rear end planed out. Just need to get everything else figured out.
With TBI I can't remember much and could use the help. I am just doing na for now because of my engine quality atm. Afraid to drive the damn thing.
I want to port my stock heads and use arp head studs. Stock rebuild the motor also for good measure. I bought this thing all dismantled and don't have much of an idea where most of the sensors go. Just plain frustrated atm.
Well finally got something done this weekend. I have been cleaning the **** out of this car. Trying to get it ready, so that I don't have to worry about everything being greasy for the swap. I actually took pictures this time. lol
This is what I got done on Friday after a couple hours of scrubbing everything down. Car was very dirty still from the previous owner and the ride from Colorado to Ohio.
The bay
There were lots of bugs and paint splatter from a friend spraying his interior with a sound deadener like a maniac. Came out ok for the time being. I can't wait till I get the top repainted.
Back wheel after a little love.
Front wheel after a little love. I couldn't stand how bad they where. They were almost black from the road grime and brake dust.
These pictures are from today.
I plan on doing some touching up everything while I have the wheel off. I will get the wire wheel out and then paint it flat black to hide road grime. This isn't a show car just may daily driver with some go.
Here is a pic of the left side 99 2wd blazer brakes that I installed in Colorado. I think I may just replace these pads just so I can get something that doesn't throw so much dust. May use the caliper paint in silver or red. Don't know yet on that.
This is the first time I have ever tried to repair and polish wheels. It is taking me much longer than I thought. If anyone has some pointers please speak up. Lots of work in this one wheel on Friday, but this is what I started with today.
These road rash marks that the previous owner left me are a pain to get out. They are slowly sanding out.
Before
Half hour later
Finished with just that one area.
I wanted to get a coat of paint on the back side to see what the slots and back would look like flat black. I like the way it turned out and will be doing this for all of the wheels.
Before
After
Small difference, but I still like it better for ease of cleaning.
Not much progress, but with a newborn I don't have much time for the wagon. I am still looking for the last bit of parts, so I can put the rear end in. Some are more costly then I thought they would be. Also have to replace the gear box now that it is going out. I think it is time to say bye bye to powersteering and get an S10 manual gear box. Good exercise too. lol
Oh and now that I have the option to use a truck pattern for the rear I will be using the wheels that sparked this adventure.
Moto metal skull wheels 18x9 -12 offset It gives me close to the 4.5 in back spacing, so may have to use small spacers but will see.
I was also looking at fabrics for the interior and will be using skulls for the head liner, black for the pillars, and vinyl black paint for the other lower portions and dash.
This is the headliner fabric I may use.
http://www.spoonflower.com/fabric/1904397
I am going to goto a junkyard soon to see if I can find the last bit of parts that I need. Hopefully here soon I can get started on this motor rebuild, so I can put this LM7 where it belongs.
