Lsx wiring for dumb ass
Old 12-30-2012, 01:31 PM
zukboi2004's Avatar
So the pins I removed from the blue plug were
23, 25, 28, 32, 33, 34, 45, 46, 53, 55, 65, 68, 70
then i removed from the red plug
2, 4, 6, 7, 8, 13, 14, 17, 18, 30, 34, 36, 37, 41, 42, 43, 45, 47, 48, 51, 53, 54, 63, 64, 70...
if i missed something let me know, i am now tracing back the wires but some lead to plugs that still have wires leading in to the harness...hmmmm
Old 12-30-2012, 07:37 PM
Majik1's Avatar
I also agree with the Megasquirt... But if you must do it by hand be sure to take your time. Dont rush it, wire each slowly, and be sure to wire and hide correctly the first time. I am ripping out all of my previous wiring now just to tuck and hide everything correctly...
Old 12-30-2012, 11:24 PM
Phantom383's Avatar
What is the harness do you have?, Is it from a F-Body or a tuck?
The White, Blue & should be a Black plug coming out of the ECU are the C plugs that connect the inner harness (gauges, OBD Port, ect.) to the PCM.
I hope I'm not off track in saying this but the Pin-out from the LT1 swap is to make a LT1 run with a LS PCM ( I did this to my 93) and might get you off track since you are running a LS motor and not a LT.
You need to pin it as a LS motor and the LT1 swap pin-out it will get you backwards if you follow the Injector pin-out out for sure.
As as far as the PCM goes, yes you will have to have it reprogrammed to remove the VATS, Trans and any other sensors and what not that you removed or not using turned off and upgraded for any changes like No2 or cam.
Old 12-31-2012, 07:14 AM
zukboi2004's Avatar
I have a Harness from a 2000 F Body with a standard, I didnt see a lot of the trans wires being used either(Trans fluid temp, trans fluid pressure, etc...)
[IMG][/IMG]
I just pulled the pins out from here.
I have my motor together n will be plugging it up in the engine craddle n routing all the wires to enter the firewall on the pass side if the motor so I can mount everything in the Glove box(OBD port, ECU, Fuse Block, Relays, etc...)
Here is the car
[IMG][/IMG]
Here is the Motor as it sits right now in my Kitchen
[IMG][/IMG]
These are the plugs in question
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
So the question is, once I am happy with how it is routed, I will prolly have to cut the wires, untangle them so they lay straight the solder n heat shrink them back together right?
Then with these left over plugs i will keep what wires out of them n throw the rest awy?
Old 12-31-2012, 07:16 AM
zukboi2004's Avatar
Thanks for all the help, n for not flaming me thruout my thread too
Old 12-31-2012, 09:27 AM
Phantom383's Avatar
Can you get me a good pic of the first 2 pics and the wires that come out of them?
I believe that they are your C100 witch should have the cooling fan switch wires & your C105 and that should have the Fused Ignition wire.
Those White & Blue ones are C plugs also.
The White (Natural) one has a Ignition fused wire in it.
The Blue one is going to have a Serial Data wire in it.
I can help ya more as soon as I know about the 2 black plugs and what color the wires are.
Old 12-31-2012, 10:26 AM
zukboi2004's Avatar
[IMG][/IMG]
Pink orange white n white are coming out of this one
[IMG][/IMG]
[IMG][/IMG]
Pink, Green, Grey, yellow, orange, n those are the wires i Can see in pics for now, at work right now
Here is another pic for fun, notice the blue bottle?
[IMG][/IMG]
Old 12-31-2012, 10:28 AM
zukboi2004's Avatar
I think those are the C100 n C105 plugs, can anyone confirm?
Old 12-31-2012, 12:41 PM
Phantom383's Avatar
1st Pic: Pink Orange White & White C105
Pink:Fused Output-Ignition
Orange: Fused input Feed
White Pin F: Cruise Control Indicator lamp
White Pin G: Tach Signal
Old 12-31-2012, 01:01 PM
Phantom383's Avatar
2nd & 3rd Pic C105
Pin A Pink Fused Feed Input
Pin B DK Green/White A/C Compressor Relay Control
Pin C DK Green A/C Compressor Clutch Solenoid Feed
Pin D Gray Reference Voltage Feed - 5 Volt Reference
Pin E DK Blue Throttle Position Sensor Signal
Pin F I believe yours is empty
Pin G Pink Fused Input Feed
Pin H DK Blue Coolant Fan Relay Control
Pin J DK Green Coolant Fan Relay Control
Pin K Black Sensor Return
This is what those wires do/did in a F-Body.
I will search my schematics that I have to find out what some of the fused Feeds linked to.
You will want anything that is Pink for ignition for sure.
Old 12-31-2012, 01:06 PM
Phantom383's Avatar
What kind of Transmission are you running and what do you plan on for a shifter?
Old 12-31-2012, 01:09 PM
  #32
zukboi2004's Avatar
So keep the pink wires for sure.
What about B C D E H J K?
how many of these do I keep?
Old 12-31-2012, 01:11 PM
  #33
zukboi2004's Avatar
running a TH350 with a Megashifter(B&M) until I get all my stuff for my LT1 t56 to fit my LS style block(Input shat, front plate, & bellhousing)
Old 12-31-2012, 01:19 PM
  #34
Phantom383's Avatar
Why an LT1 6speed?
Why not save your self some hassle and get an LS 6speed, bolts right up
Old 12-31-2012, 01:23 PM
  #35
zukboi2004's Avatar
Cause this is what is available n the budget wont allow me to buy a complete on right now. Gonna wait on all that hassle n e ways. I do have a t5 but I need either a custom($$$$) bellhousing or a custom flywheel($$$). bith not in budget. Going to run the TH350 for now with a JEGS flywheel spacer n a 3000 stall
Old 12-31-2012, 04:44 PM
  #36
Phantom383's Avatar
Well since you are going to do a 6Speed I would take all the 6Speed wires for the trans and just tuck them down under the car.
I wouldn't cut them unless you don't want those options with that transmission.
Old 01-01-2013, 08:13 PM
  #37
Phantom383's Avatar
What kind of car is that BTW??
Old 01-01-2013, 09:23 PM
  #38
zukboi2004's Avatar
A 1973 Datsun(Nissan) 240z.
From the car
Headlights, brake lights, running lights, turn signals, hazard lights,
Horn, are what I need from the car.
Maybe I should buy a regular hot rod harness n wire the engine harness into the fuse panel??
Old 01-01-2013, 09:26 PM
  #39
zukboi2004's Avatar
A real neat trick would be a under hood LED strip around the engine bay just in case
I'd I am at the track or on the road n at night I have to do something I can see under the hood, no drop light needed, maybe same in car
Old 01-04-2013, 07:46 AM
  #40
zukboi2004's Avatar
So I have the Harness broke down n am still wondering where to go from there. Will post pics later today. I have the sensors on the motor plugged in n wires laying on side.
What is absolutly needed to make these cars run?
Is VSS needed?
IAT?
MAF?
I would think the O2's would be the last sensors on the harness?
Quick Reply: Lsx wiring for dumb ass
