aftermarket foxbody gauge cluster on the cheap
started on another project for the fox today..since i have a motor swap and run megasquirt, none of my factorY gauges would work..so i sold off my v8 cluster and went to work on this 4 cylinder cluster i had...i wanted aftermarket gauges, didnt want to pay the insane amount some companies charge for custom clusters..at the Same time i wanted a factory looking cluster with factory fit and finish....well, below is how i did it..the cardboard template represents the medium of your choice for what you will mount your gauges to...it needs to be 1/8 inch thick or less..im going with a 1/8th inch thick sheet of carbon fiber
here is the stock 4 cylinder cluster
removed the clear lens
gut the body of the cluster of all factory stuff..it should look like this..KEEP THE GAUGE FACES..YOU WILL NEED THEM FOR YOUR TEMPLATE
take a hot knife or dremel and cut out the back side of the cluster...this is to give you room for the back of your aftermarket gauges
take a piece of cardboard and make a template using your gauge faces with needles and trip button removed...make all the holes etc...cut it our and fit it to the white backside of the cluster housing
re-install your middle black trim bezel and clear lens....once you are certain of the fit, make a gauge plate with your template, mount your gauges and viola !! you have a great looking aftermarket cluster for just the prices of gauges..and it fits like factory becuase you are using the factory gauge shell!!!
you can see looking from the back how much room you now have!!
**** YOU MAY NEED TO TRIM THE PLASTIC DASH PARTS BEHIND THE CLUSTER..NOT CONFIRMED YET...***
How do you plan to implement the backlit areas for the turn signals, CEL, e-brake light, etc?
I have a similar plan to what you posted but I'm going to cut the original cluster face plates to fit the gauges around the various backlit areas in the face plates. The face plates will need to be assembled together with some custom reinforcement before doing this because the gauges will cross the boundary between OEM components.
