LQ4 compatability question
Old Dec 29, 2012 | 09:34 PM
RedHotV's Avatar
Default LQ4 compatability question
TLDR, I'm going to be getting a LQ4 for a swap and was wondering if it will bolt to a TH350.
It'll be going into a GBody El Camino that currently has a 305/th350 combination in it. If I absolutely have to get a diff trans then I can. I'd have to wait longer to get the motor though since I would rather swap everything out at the same time. So if it will just bolt to the 350 then that would be great. I did a quick search but didn't see what I was lookin for.
TYIA
Old Dec 30, 2012 | 12:35 PM
ChevyMan1989's Avatar
TYIA
yes it will. i have a muncie bellhousing bolted to the back of my lq4 right now
Old Dec 30, 2012 | 01:36 PM
tfi racing's Avatar
What year LQ4?If it has the long crank you won't need the spacer,the only real issue is getting the tv cable mounted correctly,a couple of vendors have the part for that.
