DIY ls1 to 5.0 k member guys step in.
Tonight I started measuring for motor mounts. I centered the motor in the car and started measuring. According to my measurements, driverside will almost two inches shorter then the passenger. Did you guys make mirror image mounts or did you center and build. Thanks for your input guys.
I centered the motor in the car. Measured the back and front of the motor compartment then ran masking tape from back to the front and centered the motor.that way you end up with 2.different size mounts
