int or ext fuel pump
Old Jan 3, 2013 | 07:21 AM
forcd ind's Avatar
Default int or ext fuel pump
going in my 71 chevelle, trying to decide if i should go int or ext fuel pump-i was looking at one of the Tanks Inc int pumps, but if a pump failure i need to pull the tank
the engine is a 6.0, LS3 heads/intake, and a Procharger
using stock LS3 fuel rails, so i would run a return reg
prob ballpark 525 RWHP, not a max effort deal, but i would prob size the pump for 800 FW HP
Old Jan 3, 2013 | 08:04 AM
garys 68's Avatar
The chevelle tank is low and wide, no way you wont have starvation problems with an unsumped tank either way.
The baffled/sumped caprice/impala tank with an upgraded intenral pump is worth considering.
Old Jan 3, 2013 | 11:59 AM
bczee's Avatar
If your worried about having to drop the tank for servicing or maintenance.. most of the B-Body converted tanks uses an Access panel.. (cut floor board/trunk and make a cover)
I have one and it did come in handy once already.. had a loose ground inside the sender to the pump. was cutting out on me. was able to remove the access panel, fix the ground and be back on the road in 45 mins... you can see mine in my project page in my sig...
You can always go with twin internal pumps if you feel one is not enough.
BC
