Wiring help please.
Old Jan 3, 2013 | 07:53 AM
BiPoLaR ReHaB's Avatar
Default Wiring help please.
I got my harness repinned and placed in the car. I got all power connections hooked up. I don't like the way it's looking. I keep reading that the coil packs get a relay? I have 4 relays. 2 for my fans and 2 for my fuel pumps. I'm also using a 12 fuse, fuse box. I have all spots in fuse box used and from what im seeing most people dont have that many power wires hooked up? Can anyone supply a link for power hook ups? Im using the 1999 pin out diagram and the motor is a 6.0 LS1 intake and 4l60 trans in a 67 chevyII
Thanks
Stan
Old Jan 3, 2013 | 12:08 PM
bczee's Avatar
As long as you have a fuse in the Coil circuit, you should be ok without a relay.
What I did was use a main relay for the 12v IGN Circuits (power is directly to the Battery and activiate by a normal 12Ign wire), then to a Aux Fuse box before going to the sensor or device.
I've attached a PDF file for my standalone wiring of what I did.
BC
File Type: pdf
Old Jan 3, 2013 | 12:23 PM
Thanks!! That will work. I have my set the way you described but Im haveing trouble locating a spot for my keyed source to the relay that doesn't cut out when key is turned. But I'll get that figured out.
Again thanks!!
Old Jan 3, 2013 | 02:36 PM
bczee's Avatar
I just used a DVM and traced one of the wires coming from the Settering column/Key to the fuse box, When I found one that stayed hot on both the Start and Run positions, I just tapped into it and used it to activate the IGN Relay. You should be able to find one.
Good Luck.. keep us posted.
BC
