Ls2 engine control question
Old Jan 3, 2013 | 11:26 PM
Trucupey's Avatar
Default Ls2 engine control question
I am installing a 2006 Gto ls2 into a bmw and I need some help with the engine control. I am new to the ls world so excuse me if I sound too stupid.
I am geting the engine, harness, ecu, injectors, sensors, Dbw tb out of the 06 Gto. The gas pedal is not available. I have been reading to see what the best way to do this is.
Do I go with dbc throttle body or stay with dbw?
From the research I have done the 06 Gto had 24x reluctor wheels and no TAC module.
1. Can I just buy a dbw pedal and get the ecu reflashed to get rid of VATS and make it all work?
2. If yes what part number pedal do I need and who do I send the ecu to?
If I want to convert to dbc then I need to buy a throttle body and modify my harness for the tps and iacvand get the ecu reflashed.
1. Will the ecu out of the 06 Gto have the drivers to control the iac?
Any and all help will be appreciated.
Thank you
Alex
Old Jan 4, 2013 | 12:42 AM
ls1nova71's Avatar
I doubt the PCM from the '06 GTO will be able to run a DBC set up. I would just find a GTO pedal and stay DBW. Would be simpler in the long run.
Old Jan 4, 2013 | 06:23 AM
Trucupey's Avatar
Default Yes
I agree, but again my knowledge is very limited in the ls world. Any ideas where to send the ecu for reprogramming for the vats removal?
Alex
Old Jan 4, 2013 | 06:25 AM
oldgoat69's Avatar
Try Brendon at www.lt1swap.com he has done the customizing for several here, or look to the site sponsors.
Old Jan 4, 2013 | 06:47 AM
kwhizz's Avatar
I always use John at
www.speartech.com
and like Eric said.......DBW
Ken
Old Jan 4, 2013 | 02:19 PM
Trucupey's Avatar
Default Ltswap
Does anyone have the number for Brendon?
Alex
Old Jan 5, 2013 | 07:34 AM
psiconversion's Avatar
LS1Tech Sponsor
If you are going to use the E40 that came with the 24X LS2, then you have to stick with Drive By Wire. If you want to go Drive By Cable, then you will have to run the earlier Red/Blue 411 PCM and the harness will need provisions for low mount knock sensors and front mounted cam sensor. Keep in mind that the E40 Controller was only used on the GTO, Trailblazer SS and SSR for 2 years. So there arent many options to sticking with that ECM other than reworking the stock harness. We have the same motor in our Nova but went Drive by Cable as it was more in line with what we were doing with the car. Hope that info helps.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Jan 5, 2013 | 07:48 AM
garys 68's Avatar
Rock Auto for the pedal. They list it in stock. Not cheap, but less than the alternative.
Old Jan 5, 2013 | 07:53 AM
bmwhybrid's Avatar
Default ls2
Alex
I'm in the process of swaping a 06 LS2/T56 in a 97 M3 Sedan now, and want to know the same thing. I have the pedal, so I plan on using that unless runing a throttle cable is a bunch easier. Let me know if you figure it out. Thanks
Old Jan 5, 2013 | 07:59 AM
bmwhybrid's Avatar
Smile
Jon
PSI
Jon,
If I run the gto pedal that I got with the swap, I can use the ECU from the gto aswell and harness? I just need to have them paired(BMW Harness), and the GTO ECU flashed? Thanks Sorry OP, but this should help both of us
Old Jan 5, 2013 | 09:34 AM
Trucupey's Avatar
Default Jon
Jon, that really helps. I have a few more questions. Here is where I stand currently.
Option 1
06 gto Ls2 ECM and harness (I have this available to me for free)
Reprogram ECM ( remove vats and emissions) $150
Pedal $100 (did not come with the engine)
Harness rework about $400
Maf sensor $100 ( did not come with the engine)
Total$750
Am I missing something?
Option 2
01 camaro Ls1 harness and ECM ( i have this available to me for free)
ECM reprogramming $150
I have an ls1 maf
Dbc throttle body $400 (from psi)
Total $950
What is involved with the knock sensor and cam sensor modification. Is it just the harness extensions or do need the sensors also?
How about this?
https://ls1tech.com/forums/parts-cla...rness-pcm.html
Alex
Old Jan 5, 2013 | 09:48 AM
Trucupey's Avatar
Default No problem
No problem bmwhybrid seems like you are right on topic.
Alex
Old Jan 5, 2013 | 10:15 AM
bmwhybrid's Avatar
Alex
Thanks Alex, seems like option 1 is what im going with. What mounts and headers are you using?
Old Jan 5, 2013 | 12:51 PM
ls1nova71's Avatar
Option 1
Total$750
Option 2
I have an ls1 maf
Total $950
Of these two options, option number 2 should be cheaper, since you should be able to pick up a DBC throttle body for $50 or less I would think. Why did you list it at $400?
Old Jan 5, 2013 | 01:33 PM
garys 68's Avatar
You picked one of the more expensive pedals out there, it's about $250.
You can also save yourself about $375 of the $400 by doing the harness yourself.
Old Jan 5, 2013 | 01:36 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Dont forget, if you are keeping the ls2 intake you will have to extend both the map and cam sensor connectors as they are both in different locations than the ls1. That is if you go with option number 2. Who are you having do your re-wire for $400? What options are you getting with the harness for that price? Thats close to what a new harness would cost.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jan 5, 2013 | 06:25 PM
Trucupey's Avatar
Default Answers
I quoted the throttle by cable form PSIs website. It is an Edelbrock 90mm that has the 4 mounting holes for the ls2 manifold and comes with a TPS and IACV. Please let me know if you know of a source that has $50 90mm (stock ls2 size) 4 bolt TBs with the TPS and IACV.
The pedal I also quoted from the PSI website. It is $184 at Rock auto. If you know a chaper source please share.
As far as the harness rework I averaged between a few people's.
Current Performance:
Stage 2 Engine Harness Modification
Adds A/C and Electric Fan wiring as well as all needed relays and fuses.
(Can be wired for computer control or manual switch for fans)
$450-$550
BP Automotive
Premium service starts at $320 without A/C and $350 With A/C for Drive by cable and Drive by wire
As far as doing the harness myself, I am in the US ARMY and I will probably deployed again later this year and I have to manage the project in a way that I finish it before I leave. In my last conversion, 625hp 2jz into an 1998 BMW m3, the wiring research and actually doing it took me about 2weeks. I just don't have the time to do it in this project. Even with the rewire service I will have to integrate the harness into the e30 and that will take a few days. Just time management.
Thanks for all the help guys. Still up in the air with what option to go with. Please if you have sources for desent quality cheaper parts or labor give me input.
Alex
Old Jan 6, 2013 | 07:43 AM
Trucupey's Avatar
Default Lt1swap
Here is lt1swap's response :
"If it's a 2005+ LS2 with the E40 ECM, I do not program that particular ECM.
Only doing the Gen 3 engines, and the Gen 4's with the E38 ECM."
So my programming options if I want to use the Gto PCM are:
Bp automotive ? (Nothing on website), Current performance $175 (quoted on the phone), Psi $150(website) and Speartech $300(website)
Any other ideas???
I am just looking for VATS and emissions removal.
Alex
Old Jan 27, 2013 | 09:39 AM
HwyStarJoe's Avatar
Don't forget Street & Performance. They have a downloadable reprogramming form on their main page.
They can do the E40.
Old Jan 29, 2013 | 12:05 PM
2Aspire's Avatar
I have an 06 GTO LS2 in my conversion.. I went with the Gen III or Blue Green PCM part number 12586243 as I wanted to use the DBW for cruise and this was the best way to achieve.
The other reason I used this PCM vs. red blue 411, as this PCM can be used to retain cruise function as well but you must switch to the LS1 style knock sensors, was that I wanted to retain the GTO stock knock sensors..
For the GTO, IIRC the cruise is controlled through the body module or BCM if you use the E40 ECM.
Just something to consider if you want to hook up your cruise control.
