Mustang LS swap help needed!!
thanks for any insight.
If you build your own motor mounts, you don't need to change anything, assuming you build round headers which are known to fit. IE Hedman swap headers.
Yes keep us posted thanks!!!
Is this due to the truck intake or the fact that the engine just has to sit higher with the stock k? If you have buy a cowl hood with the stock K, then there would be no cost savings and might as well get an aftermarket K. But, will an aftermarket K allow the stock truck intake to be used??
Thanks for the pic, I think I can see how the engine will drop down lower into that K. Is that soild mounts or is there some sort of poly/rubber there? Cann all the stock suspension be used? Other fellow mentioned caster plates for alignment?? This is all the stuff I'm trying to avoid to be honest.
No aftermarket K, different intake, acessory drive, or hood needed!!!
I picked up a 5.3 '02, and mated to a th400 and installed it using the stock K and 4.6 mounts. The stock truck intake and TB are clearing the stock hood
I needed to notch the stock K at a corner, but she's in. I also notched the hood reinforcement "bulges" which is actually fiberglass. At first I started trimming the intake's threaded bosses and also contoured the TB until I realized that wasnt going to be enough, then I decided to trim the hood. Everything clears except the alternator which I know will be tight - I dont have the truck alt at this point but I measured the one on my Yukon to get a reference, looks like I need another 1/4"-3/8" (using the Mustang temporarily). I may have to trim the truck alt a bit, or try and raise the tail shaft a little more. Right now I have about 3* of driveline angle (engine tilted back).Couple of notes - the truck intake fits beautiful, but it hangs down about 3.5"
under the 'member. And given the fact that the 'member has scrapes on it from bottoming, the truck pan isnt an option. The F-body pan actually sits above the 'member by about an inch or more. I think the muscle car or CTS-V pan may of been perfect, but the f-body pan was here.
Couple questions for you guys: Is there a smaller alternator that can be used that will bolt-up in place of the truck alt, and anybody know what the proper drivelive angle should be for these cars??
Truck pan:
F-body pan:
Admittedly, I still need to get the UPR engine plates which are 1/4" thick, so the engine will go up a bit, but right now there about 1/2" of clearance to the hood, so we'll make it.
