Project Blue Balls // Fairmont
Old Sep 22, 2013 | 08:38 PM
  #81
A.R. Shale Targa's Avatar
Originally Posted by superbean
Still has the stock 7.5in rear end unfortunately. I have an 8.8 in the garage ready to be built
You gonna run some 3.27 or 3.55s in that 8.8 ??
Old Sep 23, 2013 | 01:03 PM
  #82
Slim80's Avatar
[QUOTE=superbean;17702480]I've driven the car a few times now...
Put a 2 speed Volvo fan on it, bled the cooling system (what a *****)
Next time you have the thermostat out just drill a 1/8" hole in the top part of it and it will bleed the air for you. I've fought with that before and after drilling the hole you just fill and go. It will burp out in the overflow tank as you drive. Did you get that starter problem figured out? I just recently ran into a similar problem and I fixed it by putting some more spacers (washers) between the torque converter and the flex plate because as I would crank down on the torque converter bolts it would ever so slightly bend the flex plate just enough that the starter gears didn't like it. Good luck with the project!
Old Sep 23, 2013 | 01:59 PM
  #83
superbean's Avatar
I'm not sure yet.. I may keep the 2.73s for a little while until I finish breaking all the other stuff. I used to have a ton of mustangs and have a few gear sets in my storage unit.. May be able to trade some of my 3.73s and 4.10s for someones stock 3.27 or 3.08 gears. Until then I'll enjoy made fuel economy lol
Old Sep 23, 2013 | 02:02 PM
  #84
superbean's Avatar
[QUOTE=Slim80;17704579]
Thanks for the heads up! Next time the thermostat is out i'll do that. It's a real pain in the butt
I may have to space the converter like you suggested. I was cranking it without the converter hooked up and didn't notice any hanging up issues and it only seem to happen when I bolted converter up.
Old Sep 23, 2013 | 02:05 PM
  #85
superbean's Avatar
Notice the return hose going into the filler neck lol. I'm going to pull the filler neck off and have a -6an bung welded in that way the fuel drains back through the filler neck instead of having to tap a hole in the top of the tank. (filer neck is removeable)
I also changed up the exhaust some. In these pictures it has straight 4in pipe coming off the turbo (loud). I pie cut 3inch pipe and made a 90 pointing it down so the fender will fit and it's about half as loud as it was.
Old Sep 28, 2013 | 06:13 PM
  #86
superbean's Avatar
I'm having a problem building boost.. I've bypassed bov.. didn't work, pulled wastegate line temporarily and that didn't work. Map is working since I did a boost leak test and saw 20Psi or so. Any ideas?
Cobbled this up for a temporary exhaust. Looks hideous but did quieten it down a lot
Old Sep 29, 2013 | 10:44 AM
  #87
TDMKR496's Avatar
I would try pulling the gate and make sure its not stuck open.
Old Sep 29, 2013 | 01:06 PM
  #88
Slim80's Avatar
What spring do you have in the wastegate right now? I would look at that area first and make sure nothing is leaking out past the wastegate because of a valve stuck open like what was mentioned. One thing I do is to put a piece of paper over the exhaust area of the wastegate to see if anything is coming out and forcing the paper away. Sometimes just putting your hand over it you cannot sense a slight leak at low idle.
Old Sep 29, 2013 | 04:11 PM
  #89
stangtrader's Avatar
You get your starter issue fixed? Reason I ask I had the same issue on my fox problem was due to the ford starter noid that I was using.just a thought I figured id share. Good to see the car on the road.
Old Sep 30, 2013 | 10:31 AM
  #90
superbean's Avatar
Wastegate seems operable. I hit it with shop air and it opens at around 14psi. At first I didn't put the ring in the wastegate, so I thought that was the problem, but it's still doing it.
I may cap off wastegate completely and drive it easy and see if it will build boost or not. That will rule it out.
I'm starting to think I may have an issue with the turbo
Old Sep 30, 2013 | 11:43 AM
  #91
TDMKR496's Avatar
Thats a possibility, does the shaft spin freely? Did you prelube it before you started the car?
Old Sep 30, 2013 | 08:42 PM
  #92
superbean's Avatar
It seems to spin fine, yes pre-lubed it and hand spun it for a few minutes before cranking the motor
Old Sep 30, 2013 | 08:52 PM
  #93
aknovaman's Avatar
Chk your txt messages from me with a picture.
Old Oct 6, 2013 | 12:05 AM
  #94
superbean's Avatar
I have been driving the car on 6-7 psi for a few days now doing some street tuning. WOT is about dialed in at a fat 10.8-11.0. Drive-ability is about 95% spot on and drive better than a factory pcm car.
6-7Psi
14deg timing
11.0 WOT AFR
Lots of burnt rubber
Old Oct 6, 2013 | 11:32 AM
  #95
lt4malibu's Avatar
whats the learning curve like on that MegaSquirt? ive been considering it for a future project but haven't really "tuned" before (just changed shift points, limiter and stupid stuff like that)
Old Oct 6, 2013 | 09:41 PM
  #96
aknovaman's Avatar
Download the software and start playing with it. It's always free and available from DIYautoTune.com Then read the user manual; its pretty intuitive.
Old Oct 13, 2013 | 09:46 PM
  #97
aknovaman's Avatar
Status update plz !
Old Oct 13, 2013 | 10:59 PM
  #98
superbean's Avatar
I'm just a redneck from the mountains of NC .. If I can wire it and it run, anyone can.
I think it's pretty simple to use honestly.. depending on your setup, you can find a basemap that is 80% correct that already has all the req fuel specs setup and saves time.
If it's lean, add fuel, if it knocks, take timing out really that simple.
Old Oct 13, 2013 | 11:01 PM
  #99
superbean's Avatar
Glamour shots!
Trip down to Wal-mart!
Groceries. 20 bags and barely filled the spare tire well..
Old Oct 13, 2013 | 11:12 PM
  #100
superbean's Avatar
Needs a rear end BAD. 8.8 Will be in it soon, just need to order a bearing set.
