Project Blue Balls // Fairmont
Plans for the car:
Junkyard 4.8/5.3 / On3 76mm turbo / TH400 / 8.8 2.73 Gear
I will be picking up the TH400 here soon locally, that's all that I am missing..
I have two 5.3s in good shape, and a 4.8 shortblock so I'm not afraid to boost this thing until it blows!
Here is Project Blue *****:
This one will be getting a 255/60/15, but I was thinking about painting some white walls on it to throw the untrained eye off. Wheels I plan on running are some steel wheels or ten hole stang wheels. Both make decent sleeper wheels!
Engine:
LM7 5.3
140k~
706 heads
LS1 Intake
Stock truck TB
Forward facing truck manifolds
Home-brew crossover
On3 76mm turbo
Tial bov
50mm waste-gate (Probably run 14psi on street)
Trans:
Th400
RV deep sump pan
24"x48"x1" trans cooler
Trans cooler fan
3600 Art Carr converter with anti-balloon plate and billet snout
Still debating on transbrake (maybe later)
going to try to retain shifter on column for sleeper appeal
Differential:
90 Mustang GT 8.8
Factory Trac-lock unit
Stock axles (to get it moving)
Then Yukon axles (no c clip elims.. riding on the edge of destiny!!!!!!! lol)
Fuel/Tuning:
Bosch 044 Pump
Vette fliter/regulator
-8AN feed
Camaro Fuel Rail
80# Injectors
Still debating on MS1 for fuel and 6010MSD for timing maps
..or..
Ms3 with x board to run sequential fuel injection
Interior:
Just a bunch of go fast gauges so I don't blow **** up
Exterior:
Some honk for Jesus stickers
My child is a terrific kid stickers
Maybe some different tires that actually have tread on them
Car will go under the knife to remove the 200 I6 / Auto very soon!
Hell i eyeball ever mont zephyr i see as ive liked them since 1996 or so.
No stickers on mine, but the license plate is Hooptie
Artistic shot!! lol
I'm also still waiting on my transmission. It is currently in a motorhome that a friend is parting out, so I have to wait for his lazy *** to pull it for me to modify this fox body / th400 transmount I have (wont need much, just the mounts are about 2 inches narrow than a mustang. After the trans is in I can measure for a driveshaft
While I am waiting for parts, I am going through this 8.8 rear end. For now it will be mostly stock, fresh Trac-loc unit, going to open it up and check the ring and pinion to make sure it looks ok. New carrier and pinion bearings, seals and brakes.
This k member is 01GT mustang k member, fit pretty good where the two larger bolts in the spring bucket go into the frame rail, but the two smaller bolts in the back needed to be elongated a hair to make fit. Still much easier than having to make my own mounts as I have the LS >> 4.6 Mod motor conversion mounts.
It feels kind of wired not taking everything apart, cleaning pieces up and painting them and making it all nice under the hood like I do my other cars. But this is budget ghetto grandpa go fast power, so **** it.
