Is a VSS required on 2005 DBW Vortec with a manual trans?
I've read about the issues with not having a VSS on a LS/Manual Trans combo and having stalling or almost a stall when the clutch is depressed. The explanations I read said it had to do with the IAC valve and not being able to transition quickly enough.
My question is that since the newer style DBW throttle bodies don't use an IAC is this still an issue?
I'd like to make use of an old Muncie 4 Speed and not have to deal with fabricating a vss setup if it's not really required with the new throttle bodies handling the idle.
Thanks, Ken
Thanks, Ken
I've done 2 DBW manual trans swaps (an 02 and 05). I was able to repoduce the stalling issue in both. All you need is a dakota digital pass thru vss hooked up to the muncie speedo output. It doesn't even have to be calibrated correctlt.
you need a vss as it reports to the pcm and gets translated into speed...which teh pcm uses for various calculations....including idle while moving, and coming down to idle while moving.
while some things may seem to work with an uncalibrated vss as gary is saying....
they do not work correctly and can make tuning a pain in the ***
SEN-01-4160, screws into the Muncie/T10 speedo output. Your speedo cable screws into the VSS. I would suggest buying the short adapter cable (not listed on their website). It can get tight in the tunnel.
http://www.dakotadigital.com/index.c...rod/prd109.htm
I'm wondering if the stalling or near stall might be attributed to the CPP not being hooked up.
Not sure what the CPP does in the software but I would expect that when the clutch pedal is pushed the load percent drops to zero all of the sudden. My guess is that if the CPP is hooked up and turned on in the software that there might be some sort of compensation that happens.
I'm not a tuner so I can't say. Someone that is intimate with HP tuners or the Software in the PCM might be able to tell me that I'm on to something or if it's a dead end trail.
Well the CPP switch does shut down cruise control if you're using that. Not sure if it does anything else in the ecu.
It does do that, but won't cause it to stall. There's a good chance that you could go into the tune and change settings on the DFCO and help, if not stop, the stalling even without a VSS. I wish I had one here to play with a little to see if that would work.
