How to get a temp signal
also there are two wires coming off the 5.3 sending temp unit. how do i wire that up to check of it could work?
How it reads?? Will I'm close enough for me for i only have a cold to hot gage and do not want to change for i like the looks of the stock gages. This port is the hot side of the pump BUT it also has the cold coming in from the radiator and puts the pump tump 20-30 degrees cooler. so not a good spot for the temp gages WITH the temp numbers.
https://ls1tech.com/forums/picture.p...ictureid=98177
