ls1 in a 03-07 Silverado
Old 01-23-2013, 02:50 PM
Jadedbird's Avatar
Default ls1 in a 03-07 Silverado
Alrighty so im considering taking my ls1 that i have sitting in my garage and dropping it into a silverado
Now i know the blocks are identical so it should drop in
but i have a few questions
what will i have to do to run a ls6 intake on it?
will the truck throttle body match up with the ls6 intake?
will i have to run ls1 front accessories or can i stick with the truck accessories?
will i have to run a new pcm and engine harness?
regular silverado headers would work right?
and what would need to be done if it was a 4.8L truck?
sorry im new to this and ive tried searching but there are no write ups, only references that ive found
Old 01-23-2013, 08:22 PM
greenturtle05's Avatar
Check out http://www.ls1truck.com/forums/index.php
Old 01-23-2013, 09:37 PM
Jadedbird's Avatar
Ill have to check that out indeed
Old 01-23-2013, 11:02 PM
t_raven's Avatar
I've seen guys use LS6 intakes with truck accessories. Ls1truck has an thread about swapping intakes
http://www.ls1truck.com/forums/front...take-swap.html
Unless you care about the weight savings, since trucks are heavy anyway, you might consider selling the LS1 and buying a 6.0. The difference in value could be used for some mods
Old 01-24-2013, 10:34 AM
Jadedbird's Avatar
Well i have a 5.7 sitting around with low miles. Ive tried selling but everyone wants me to give it away haha
Old 01-24-2013, 11:20 AM
Smoke23's Avatar
I was told by Street & Performance the flywheel had to be changed out or the hole need to be egg shaped. I also have a fresh 5.7 short block laying around but people want it given to them as well....
Old 01-24-2013, 11:57 AM
Jadedbird's Avatar
Could i use my flywheel off the 6.0?
Quick Reply: ls1 in a 03-07 Silverado
