fox body mustang sbc swap
I am doing a sbc swap on a 89 hatchback mustang. engine came out of a 92 z28 w/a 700r4 tranny. i want to keep the stock k member for now. any ideas on what motor mounts to use? or go with solid mounts? its going to be a daily driver.
there is a sbc section on this site
https://ls1tech.com/forums/small-blo...y-specific-92/
i recommend the AJE k-member and it will make your life much easier.
***edit***
I just saw that you posted on my build thread
***edit***
The motor is pretty solid. Fresh rebuilt. .030 over master kit. Polised crank and rods. Gapless rings.highly Ported and polished 305 HO heads. Flat top pistons. Stock cam. Edelbrock performer intake, edelbrock 600 cfm manual choke carb. 1.6 roller rockers. The tranny is a 700r4 with shift kit and corvette servo.
I'm going to be putting my money on my actual build. Ls3 will be built out of car on the kmember, once ready ill just drop it in.
I'm tired of ford blocks. Had 2 blocks split with a mild build.
You split two sbf Fords with "mild" builds? Not sure what you consider mild, but unless you're definition is something in excess of 550whp something's being done wrong in the bottom end. For that matter, a 351w will take a lot more abuse than a 302.
http://s1158.beta.photobucket.com/us...68874957684958
[video src="http://s1158.beta.photobucket.com/user/javila2468/media/879.jpg.html?sort=3&o=0#/user/javila2468/media/868.jpg.html?sort=3&o=11&_suid=1359933737708015268 874957684958" linkfallback="linkfallback"][/video]
Read more: http://hybridpony.boards.net/thread/...#ixzz2Jxm68tKI
Dropped the motor and tranny in on sunday. Ran into clearance issues with the Gen 1 SBC stock oil pan. it hits the k member. i'm going to go with the AJE k-member after all BUT i have read in multiple thread in here that the stock oil pan will not fit the k-member. Will I still be stuck with oil pan clearance issues??
![](http://i17.photobucket.com/albums/b99/don94/E102C352-9F27-498C-87E5-0BB2768FF5AA-589-0000003A75500849.jpg)
![](http://i17.photobucket.com/albums/b99/don94/DC5CB530-B306-4C41-8E98-E3E9F4E28730-589-0000003A6D9DF843.jpg)
it was a thread here in LS1Tech...i can't find it anymore...i'm just going to stick with the AJE k member, spring perche and motor mounts..(ordered today, hopefully will come in soon)...i saw what you did with the crossmember...looks good...i'll do that to mine.
