6.0 LQ4 into a 72 Buick skylark convertible
#61
![Smile](https://ls1tech.com/forums/images/icons/icon7.gif)
after letting my car dry out over night I put the plugs back in and changed the oil. Bob Ream From Imagine injection where I bought the fuel injection package from came by to assist me in the starting process. He just made a friend for life. I had a few things to work out before it would start, But it finally fired up. Engine was surging until we got a good 12volt source to the ECM. I used the original resister wire. Derrrrrr. when it calibrated the fuel mixture the throttle response and idle were awesome! Need to straighten out a few things but should be driving it soon.
#62
Got the alternator working and a new 12guage wire to the 12volt switched junction block and started it up. running a lot better with a good ignition wire to the system took it around the block. now need to setup transmission control unit
#65
After 300 miles driving the car I have only had to tighten up a few hose clamps and bolts. Brought it in for a tune and bumped the timing from 31Total advance to 34. played with the fuel curve a liitle for off idle response.
It has been awesome, have surprised a 99 corvette and a 2000 Carerra gt.
Getting 18MPG in city driving. I am glad I went with the 6.0, it has so much torque, only problem is cleaning the rubber off the exhaust pipe extentions.
1967, 4l60, 71, 72, brake, buick, chevelle, conversion, convertible, crossmember, lq4, measurements, skylark, swap, working
