Fox Mustang Swap with AC?
Old 03-08-2014, 08:20 PM
rmelton28's Avatar
Default ac box
Originally Posted by dville_gt
The benefit in my opinion is that all the components are designed to work together and are R134a from the factory. Plus the a/c pressure sensors screws right into the accumulator and all the connections are factory GM o-ring style. It might be a little more work, but in my opinion the end product is just nicer. It looks like a PITA and expensive but it really isn't just lengthen a line and make one new line. The hardest part is glassing the heater box to fit the larger evap.
Or just cut the ls style fittings off the evap and have them welded to the ford evap like i did.. Cost me 20.00
Old 03-10-2014, 03:54 PM
geoff17's Avatar
For my setup I used a sanden ac compressor, fox evap stuff under the dash, 4cyl fox condensor, generic accumulator mounted in the fenderwell and custom built ac lines and a stock 4cly liquid line. Came out pretty good imo and blows rediculously cold, even is Florida's hot muggy climate.
Old 03-10-2014, 03:59 PM
TxFireman1972's Avatar
Nice setup. Is the accumulator mounted forward of the shock tower or behind it?
Old 03-10-2014, 05:35 PM
geoff17's Avatar
Forward the shock tower. You can kinda see it right at the end of that 45 on the line off the compressor.
Old 03-13-2014, 10:08 AM
The Guy in MY 99TA's Avatar
geoff17 I LIKE!!!!!!
Old 03-13-2014, 10:09 AM
only thing is I want to mount mine down low and use the factory AC line b/c I am only going to run an alternator with a race style electric water pump.
Old 03-13-2014, 03:15 PM
geoff17's Avatar
Gotcha, yeah that gets tricky when you flip manifolds around backwards, lol. Which factory ac line are you trying to re-use? The 4cyl mustang liquid line can be retained if you use a 4cyl condensor. Thanks for the compliment btw.
Old 03-17-2014, 04:24 PM
I have no clue why I said a/c line. I meant to type the factory a/c mounting bracket.
It'll be all custom lines.
I hope to get my car home next month( I leave for work in the gulf tomorrow night) and start tearing into it. It's still at my buddies shop for now.
Old 09-20-2014, 12:34 AM
Tanus's Avatar
I know this is an old thread, but any of you have to do any ecu mods to keep the motor from stumbling/dying when you kick the ac on.
Old 09-20-2014, 06:58 PM
1bad03snake's Avatar
You can adjust for it in the tune
Old 09-21-2014, 11:42 PM
ringgold's Avatar
Good thing I stumbled across this thread.
I have a 79 Mercury Zephyr that I would really like to retain A/C on. It currently works on the car and I am unsure of what I can save or what needs to be changed when I swap the engine. Guess I will cross that bridge when I get there.
Old 01-09-2022, 12:29 PM
  #32
Crimsonking00's Avatar
Default I know this car
Attachment 606981
Attachment 606982
Attachment 606983
I know this is a super old thread but this is definitely my car now. Super cool looking through all the paper work.
The following users liked this post:
G Atsma (01-09-2022)
Old 01-09-2022, 08:47 PM
  #33
dannyual777's Avatar
Location: Montgomery (Lake Conroe,) TX north of Houston
So the calypso green Fox that used to belong to geoff17 is now your car? If so, do you still get those 24F vent temps? I used to get 40F with my R134a converted 1991 GT. It was ice cold and nothing ever froze up.
I had to rebuild the AC in my 2002 WS6 Trans Am in Dec 2020. All new components with the exception of the evaporator. I pulled a good vacuum on the system. Vent temps are a little disappointing at 45F, however, it keeps me cool and comfortable in the Houston summer heat.
Most of my 1991 GT’s AC system is going in my LS376/480 swapped, 91 Fox coupe. I’m hoping for 40F vent temps.
Old 01-10-2022, 01:11 PM
  #34
yes I do own Geoff’s car now which has since been named sandy. The a/c system will still freeze you out at least it did the last time I drove it . I don’t have any actual temps to show at the moment the car is currently being torn down for a rebuild. Tune went lean and blew out 6 pistons
Old 01-10-2022, 01:49 PM
  #35
Oh ! Sorry to hear about the lean tune and damage!
Thank you for confirming that you now own what used to be Geoff's car with the ice cold air conditioning.
Quick Reply: Fox Mustang Swap with AC?
