Speartech Gauges for 6L80/6L90 Swap Projects
Old 02-05-2013, 12:04 PM
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
Default Speartech Gauges for 6L80/6L90 Swap Projects
We have finally released our gauge package aimed mainly at projects using the 6L80 or 6L90 transmission.
We've been working on these for quite a while. The main thing we were after on these was the gear indicator for the transmission.
The gauges will tell you what gear you're in both during normal driving, and especially when you are using the tap-up/tap-down feature in manual or sport mode!
The speedometer and tach are 3 3/8" and available as a Basic Set which displays the outside air temp, transmission gear, and odometer/trip meter:
Also available is the Deluxe Set which includes the above PLUS a window that you can select what you want displayed such as clock and date, digital display of the various engine sensors, etc.:
Also available as an option are the various 2" satellite gauges: oil pressure, water temperature, voltage, and fuel level:
Here are the gauges installed in our 01 shop truck to give you an idea of the relative size:
More info, options, pricing, and a video of the gauges in action on our website.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old 02-05-2013, 12:45 PM
Chocolate Apocalypse's Avatar
I've been waiting for something like this to come along. My column shift Cutlass has the shift indicator in the speedo and I didnt want to lose that. Any chance for different colors and fonts?
Old 02-05-2013, 02:22 PM
Speartech's Avatar
Right now, these are the only choice. I tried to pick what I thought was the best looking size, font, and color. I know everyone has their own preferences, but until these get a little circulation, this is it.
__________________
www.speartech.com
Old 02-05-2013, 05:53 PM
fox12303's Avatar
2 3/8" Tach and Speedo, they look bigger than that in the picture compared to the 2" satalite gauges. Is that the correct dim? Hopefully black with white lettering will become available in the future.
Old 02-06-2013, 10:20 AM
Speartech's Avatar
You are correct! 3 3/8" not 2 3/8".
Original post corrected. Thanks.
__________________
www.speartech.com
Quick Reply: Speartech Gauges for 6L80/6L90 Swap Projects
