What's needed to bolt a 6l80e to a ls1
I'm assuming you didn't get the flex plate with the 6l80? The flex plate bolts directly to the crank (no spacers) with some washer-head bolts, and similar bolts connect the torque converter thru the flex plate. I'd see if you can get the stock bolts from GM at a reasonable price.
Im plainning on converting the ls1 to 58x and using ls2 computer with speartech harness.
Does anyone know where i can get an aftermarket flex plate or have the gm part number for the stock one.
