4l80e crossmember for fox.
Old Feb 8, 2013 | 06:01 PM
zapp109's Avatar
Default 4l80e crossmember for fox.
Did some research from what ive found no one makes a direct bolt on crossmember. So what to do? I ws hoping aje would have one but no luck according to their website.
Old Feb 18, 2013 | 06:34 PM
zapp109's Avatar
bump it
Old Feb 19, 2013 | 02:06 PM
Sarg's Avatar
Reason being is that the tranny does not fit in the tunnel without some "massaging" of the tunnel with a hammer. I am about to have to make one as well.
Old Feb 19, 2013 | 02:19 PM
zapp109's Avatar
when you get it in take some pics, or if anyone has a some pics installed id like to see what the crossmember looks like.
Old Feb 19, 2013 | 03:17 PM
Sarg's Avatar
I might work on that this weekend. That, wiring the motor and running fuel lines are all I have left to start the vehicle.
Old Feb 19, 2013 | 03:52 PM
zapp109's Avatar
cool, yea my trans was supposed to be here this week but it may be another week or 2 so i just want to know what im getting into.
Old Feb 19, 2013 | 04:43 PM
Sarg's Avatar
Plan on beating the crap out of your trans tunnel or cutting it out and welding in new panels. Specifically around the fluid lines and the large electrical connector. Those were the areas I had to massage.
Old Feb 19, 2013 | 05:07 PM
zapp109's Avatar
you have newer style or older case?
Old Feb 19, 2013 | 05:29 PM
Sarg's Avatar
Older style.
Old Feb 19, 2013 | 05:51 PM
ZONES89RS's Avatar
In-Zane Moderator
I build the Trans cross members for nearly every LS swap I do. The exceptions have been the older 88-98 silverado and Sierra.
Old Feb 19, 2013 | 07:33 PM
boostnut's Avatar
I used an AJE mount for a 4L60 (or similar, don't know for sure) and added a fabricated mounting bracket behind the stock mustang brackets. Still using the stock bracket, just not exactly as originally intended. There's a few pics here:
http://s1093.beta.photobucket.com/us...ibrary/mustang
Tunnel is going to meet the BFH soon, the body of the 80 fits fine but the electrical connectors & fluid lines are another story.
Old Feb 13, 2017 | 08:06 AM
68roadrunner's Avatar
are there any other pre-made options for a 4L80E crossmember in a fox platform?
Old Feb 13, 2017 | 09:14 AM
user 4737373's Avatar
I'm in the middle of developing one right now as part of the upcoming Hooker Fox body LS swap system...this image shows a 4L80 install mocked up on the crude prototype, which is then digitized and turned into the actual production design within our CAD program.
Old May 9, 2017 | 10:06 PM
joe8mx's Avatar
nice to see this thread. I havent seen many 4l80e fox ones that were worth a crap. Bout to be doin this to mine. I really like that ^^
Old May 9, 2017 | 10:09 PM
ZONES89RS's Avatar
In-Zane Moderator
Just build your own and it will fit the best.
Old May 10, 2017 | 08:45 AM
This photo will give you a better idea as to what the finished product will look like.
Old Feb 6, 2018 | 11:11 AM
Trans Am WS6 420's Avatar
Anything ever come of this? My notch lq9/4l80e project (son's first car) is crawling along...
Old Feb 6, 2018 | 11:22 AM
The Hooker LS Fox Body engine brackets and transmission crossmembers are the next products in line for me to push on getting released and on the shelf. I had to hold the crossmembers back to be validated for use as part of a Coyote engine swap system that came after the development of the LS system. Now that the validation work is done, I can proceed towards release. From this point we're probably looking at 45 days.
Old Feb 6, 2018 | 12:14 PM
DailyGTO's Avatar
Nice to see someone finally making something for the 4l80 in a fox. I found they (the trans itself) fit in the tunnel pretty well with just a few hammer taps but like shown above, you can't just bolt a cross member in. I used my AJE 4L60 cross member and welded in a couple new brackets like a few others did. They sure did not look as nice as the holley/hooker's will but they got the job done for cheap!
