Turbo LS G-body with A/C?
Wanting to bump this thread up as I'm now in the process of fitting manifolds to see what I can get to work. Using the low mount truck ac compressor and the holley drive side bracket with brp mounts. Truck manifolds hit both the alternator, and the heater box. Truck manifold facing the normal way on driver side will run into the prop valve and frame.
Contacted KB racing to inquire on one of their turbo manifolds, and would use a crossover pipe under the trans, and either a C6 or LS4 manifold on the driver side
