Lsx coupe (budget) built question
Old Feb 15, 2013 | 11:53 AM
AR's LSnotch's Avatar
Default Lsx coupe (budget) built question
Sup guys, I have a 1993 notch am dropping a 2007 5.3 I wanna stay N/a for now an I was thinking runing the ms3 237/242 .603"/.609" . I seen couple guys running them on ther 5.3 as for heads this 5.3 Came wit 243s, well wen I pickd up the motor the heads were off but the guy said he took them off I will have cast number later of block cus I been hearings n researching the 2007 5.3 came wit aluminum blocks an wit 243s correct me if I'm wrong . So wat do u guys think would be a good combo for a N/a setup as for the heads not touching the 243s as for intake running a ls6 manifold. Car gonna see mre street than track weekend car
As for trans I will be running a 4L80e with a 3600 stall converter an for gears am not sure wat to run
Can u guys help me out here an knowledge me on LS motors am new to this world thanks
Old Feb 15, 2013 | 05:26 PM
LQnotch's Avatar
you have the right combo planned stick with that
Old Feb 15, 2013 | 07:17 PM
Just testing waters around how much power would I be looking at an wat gears should I run an wat size injectors should I run or I should be fine I dnt wanna max out in dyno tune
