GEN IV engine with mech. clutch ?
Old Feb 18, 2013 | 07:03 PM
cgo's Avatar
cgo
Default GEN IV engine with mech. clutch ?
Hey guys, I've been searching on here and all over the net. I'm mating a beefed up, rebuilt Muncie to a GEN IV LS and I've been trying to find a Z-Bar bracket that will work with the engine. SDPC sells a bracket, but they say it will only work with a GEN V or VI block.
Anyone found or fabricated something that works for the Z-bar ball mount?
Old Feb 18, 2013 | 07:23 PM
LT1Altered's Avatar
I think SDPC means GEN III / IV, not GEN V / VI.
Does GEN VI even exist yet?
I think it's a typo - I'd just call them and check.
Old Feb 18, 2013 | 08:18 PM
badazz81z28's Avatar
Make sure you header combination will work with it...I'm starting to regret going hydraulic...200 miles and already an MC failure.
Old Feb 18, 2013 | 09:16 PM
S10xGN's Avatar
My old scattershield has a bracket attachment point on it, but I was planning on a juice clutch. You could have one welded to your existing bell...
Old Feb 18, 2013 | 09:46 PM
i r teh noobz's Avatar
Maybe they are referring to GEN V and VI big blocks?
Old Feb 19, 2013 | 08:01 PM
cgo's Avatar
cgo
They say they didn't make it for Gen IV or below blocks.
I have a Quicktime bell housing and their bracket won't work with it. The edge sticks out too far.
I'm a welder, so I may try to fab something and weld it onto the bell housing.
I've heard the stories about hydraulic clutches, but the Keisler kit looks nice. They say it's rated for at least 30k miles... Well, site says "300,00" miles. So, I'm guessing they meant 30,000 miles. Not a lot, but as little as I will drive the car, probably take a few years to get that many miles on it. They claim it is designed much like a modern car's clutch system.
Should be way more header clearance with this than the mechanical linkage. Pricey though.
Old Feb 19, 2013 | 08:04 PM
S10xGN's Avatar
Have you looked at the Howe 82870? I'm about to grab one (they're ~ $110). Their website says "not for street use" so I called them and was told it's a liability issue and they've had units in service over 10 years.
Old Feb 25, 2013 | 02:30 PM
bowtieguy79's Avatar
Doing this swap now, we modified the SDPC bracket and got it close, still needs a minor tweak to make it feel right.
