Engine mounts won't line up
When lowering the engine, I can get the long bolt in without problems on one side, but on the other side, the mount on the engine will rest about 1" above the bolt hole on the clamshell thing mounted to the frame. The distance between the mounts on the engine and on the frame just doesn't match up good enough.
From what I've read, this isn't exactly an unknown problem - but what is the best approach for solving it?
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
How could it be a difference between different adapter plates on whether they work or not with the clamshells? I can't figure out how different plates would make this problem any different, but then again, I have no idea anymore.
Imo... it is best to bolt the adapter, engine mount (in your case, the clam shell mount) and the frame mount all together on the engine. Then drop it in and adjust the engine location to where you need it and then mark the frame mount on the cross member. Then remove the engine and drill new hole for the frame mounts or modify them. Yes this will require removing the frame mounts from the cross member and remounting them, and yes it can be a PITA..
Tip. Use weather stripping glue and glue the nut to the washer ( NASCAR lug nut trick). Them use some blue tape to keep the nut/washer in the shocker or wrench while you hold the nut in place while you tighten the frame stand to the cross member. That is how I held them in place going through them little acess holes in the cross member/frame.
But at least you know everything lines up and you have the engine right where you want it (front or back).
Good luck either way you go.
BC
Imo... it is best to bolt the adapter, engine mount (in you case, the clam shell mount) and the frame mount all together on the engine. Then drop it in and adjust the engine location to where you need it and then mark the frame mount on the cross member. The remove the engine and drill new hole or modify them. Yes this will require removing the frame mounts from the cross member and remounting them, and yes it can be a PITA..
Tip. Use weather stripping glue and glue the nut to the washer ( NASCAR lug nut trick). Them use some blue tape to keep the nut/washer in the shocker or wrench while you hold the nut in place while you tighten the frame stand to the cross member. That is how I held them in place going through them little hacess holes in the cross member/frame.
BC
just a thought...
BC
