programmer for a 70 chevelle lq4/t56
Old Feb 27, 2013 | 09:41 PM
ChevyMan1989's Avatar
Default programmer for a 70 chevelle lq4/t56
so i just about finished converting me wiring harness over to stand alone and im getting ready to try and start the engine for the first time in the car. i dont have any gauges in the car yet so i have no way of monitoring whats going on. also i removed that cats (obviously) and know i need to tell the ecm i did that. a freind of mine has a Superchips Flashpaq model #2865 hes looking to get rid of. i already looked it up and found that that programmer fits my engine. my question is... for now is that going to do what i need it to? will it turn off cats? can i monitor all the necessities? or at least communicate enough with the ecm to know that that wall was converted over correctly? this is just a temporary thing. i just need something to get by until i get all my gauges in and until i pull my engine and build it up then need go for a dyno tune.
Old Feb 27, 2013 | 09:50 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I dont believe that tuner will remove the vats from the system. We offer very affordable basic stand alone tuning for far less that what most hand held tuners cost.
If you dont remove the vats or install a bypass module you will not be able to run the engine.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Feb 27, 2013 | 10:02 PM
like i said this is just a temporary thing until i get the car done and actually get it dyno tuned.
the engine is out of a 2004 express van. bare bones no options what so ever. i didnt think i had to worry about VATS in it? am i wrong?
Old Feb 28, 2013 | 12:02 AM
LS1Tech Sponsor
If you do not remove the vats the engine will start and only run for 2 seconds.
__________________
1-888-467-4491
Old Feb 28, 2013 | 06:29 AM
psiconversion's Avatar
LS1Tech Sponsor
What year is the engine? We are in Ocean County and can get the PCM flashed so you can get to the dyno. Shoot me a PM.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
