ls fox motor mounts
Old Feb 28, 2013 | 05:43 PM
MR HYDE's Avatar
Default ls fox motor mounts
I have a 83 mustang fox body and am looking for motor mounts to bolt into the stock k member is there any available? I building them the best or only way? Is there a write up on how to build motor mounts? ( how to place the motor e.c.)
I have done a search and not found anything if this is already be discussed I apologize in advance.
Old Feb 28, 2013 | 06:07 PM
MIKE93SVT's Avatar
open your searches. brp hotrods makes drop in motor mounts. but they're expensive. or search "mustang mounts" and you see plenty of easy examples of how to make your own. some 1/4in flat steel, and some 1 1/2in square or round stock. very simple. get the motor back and low as possible and keep it level
Old Feb 28, 2013 | 08:25 PM
psiconversion's Avatar
LS1Tech Sponsor
Dirty Dingo is working on them. Should be reasonably priced and available soon.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Mar 4, 2013 | 03:37 PM
MR HYDE's Avatar
Yeah that BRP stuff isnt worth it. left to right obviously keep it centered and level what about front to back still level?
Old Mar 4, 2013 | 04:21 PM
dmracing's Avatar
I went with Brp because of header options. Where else can you get race headers 1 7/8 to 2 inch coated step header fot 800.00
Old Mar 4, 2013 | 05:33 PM
MR HYDE's Avatar
I am going to use a turbo with stock manifolds
Old Mar 4, 2013 | 08:49 PM
98LS1driver's Avatar
what would be the best way to make sure that the engine is best level
Old Mar 5, 2013 | 09:05 AM
87lsttop's Avatar
I built my own. Not as nice as brps but I went through every step I could think of to make sure that the engine was centered and checked engine angle for every little thing. It took me a while but it turned out good. I fabricated them for use with the upr 50 k member.
 Michael S. Palmer
Old Mar 15, 2013 | 04:29 AM
MR HYDE's Avatar
If you garage is not level what what have you guess used to level out the car?
