LS1/LS2 in Hyundai Genesis Coupe
I have a genesis coupe and I'm planning on putting an LS1/LS2 in it in about a month. I need some suggestions on parts. I wanna hit 500whp NA. I'm for sure running custom long tube headers and e85 to start. I'm thinking a decent sized cam and heads should bring me there. Suggestions highly appreciated. I'm new to the LS platform.
Good luck with the swap, how many of these are swapped already? I know of atleast 1. Big cam, CNC heads, good Intake Manifold, and good flowing headers will get you in the 450+ range.
enjuku racings and then g&m performance. i have some tricks up my sleeve though haha. its gonna be sick.
With just cam and heads, dont see 500 rwhp unless you get a ls3 or put some boost on the ls1/2, a 408 would definitely get you there, and a 383 would put you just under 500rwhp on pump gas, so I dont know maybe a higher compression motor on E85 might see close to 500, good luck,
I do know a 383 LS1, heads, cam, and 11.2:1 compression with 4.08 gears is 481rwhp on 93oct
