S13 240sx
Old Mar 10, 2013 | 03:46 PM
Jadedbird's Avatar
Default S13 240sx
So i can pick up one for a steal. And i found a 5.3 drop out for cheap as well
Ive looke every where but i cant find the answer.
I would most probably buy the sikky kit and swap a 5.3l and a t65.
Would that truk pan and truck accessories and truck wireharness/pcm work?
Thanks!
Old Mar 10, 2013 | 04:16 PM
brewster240's Avatar
youve looked everywhere?
i find that hard to believe. its posted all over the internet that you need a gto pan or aftermarket front sump pan (such as sikky that you mentioned...) and you need car accessories.
you will also need car intake, unless you dont want to run a hood. computer and harness can be made to work.
Old Mar 10, 2013 | 04:17 PM
Jay Gadsby's Avatar
No. Truck intake is too tall, truck accessories to wide. The PCM may work though. There is a lot of info on here. Also check the links section of Conversions and hybrids for more info.
Old Mar 10, 2013 | 05:23 PM
psiconversion's Avatar
LS1Tech Sponsor
Year of the engine will determine if the pcm is going to work (24X, 58X, DBC or DBW) especially if you are going to swap the intake and possibly throttle body to fit under the hood. What are specifics of the engine (year/make/model)?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Mar 10, 2013 | 06:58 PM
Jadedbird's Avatar
Yes I searched on here. I only found 2 build threads that were predominantly pics only.
Its a 89 240sx and the motor is out if a 2003 silverado. So its a dbw 24x
I will run a ls1 tb and ls6 intake
