Easy harness question? What to do with this connector to fuse box?
Putting a 99 LR4 in a 75 Mercedes. Using the stock truck harness.
![](http://i140.photobucket.com/albums/r12/914turboford/connector_zps934034cb.jpg)
Am I right in my thinking that connecting this to the right stuff and the rest to the engine and pcm will make it run? I think I need to hook up the pink and orange to 12V+ and the black to ground . Then what about the light green, dark green/white, purples, yellow, dark green, dark blue and light blue?
That's part of the factory bulkhead connector that tied the engine compartment harness to the under dash harness. Theres more to it than just "connecting this to the right stuff"- are you removing any of the emissions systems? Making any other mods?
If aren't using the original fuse panel that the connector in your pic plugs into then you won't be usin that connector at all.
Lt1swap.com has a pin out of what wire goes where. You would need to follow the diagram on there and label each wire then cut it from the connector.
