Stumble/miss at part throttle/cruise
when i put my car together i some how managed to get the O2 sensor plugs on the wrong sides (bank 1 on bank 2 O2 sensor and vice versa) and had the same symptoms that you are having. stumble/miss at low rpm and cruising but at wide open throttle it didnt miss a beat. never threw any codes either. swapped O2 sensor wires to the proper sides and its been working flawless since. hope this helps.
LS1Tech Sponsor
What MAF are you using? If it is the cartridge style, that could be where to start.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
