Help: Need ideas
Old Mar 21, 2013 | 12:44 PM
OSU Sam's Avatar
Default Help: Need ideas
I am wanting to build a older car. Nothing rare but something like a 64 Pontiac lemans. I want to put a supercharged ls3 in whatever I build. Basically I want to build a car around an engine and tranny. I was thinking the tremec tr6060 with the edelbrock ls3 crate engine. I want to put it in a big car. Such as a lemans or anything that looks like that sort of style. I want to modernize the suspension or put a late model chassis under it. Not sure what is best to bolt the engine to as far as fit. I'm open to suggestions.
Old Mar 22, 2013 | 10:34 AM
OSU Sam's Avatar
Anybody?
Old Mar 22, 2013 | 11:32 AM
bczee's Avatar
64 Lemans ?.. its been done before, or many simular projects are already done. try a search. search for the Raybestos GTO. You not asking to do anything that is not out of the norm now a days... Many aftermarket chassis to stick under many full frame cars (GM A-Body) or Subframes ones (F-Body, X-Body).
Suggest you research and read some of the Swap / Project Threads here on LS1Tech and other Forums.. will pertty much outline everything you want.. Check out the FAQ / Sticky in this section.
You can check out my Chevelle and Nova projects by following the link in my Sig.
BC
Old Mar 23, 2013 | 01:36 AM
OSU Sam's Avatar
Thanks very much!
Old Mar 23, 2013 | 06:14 AM
oldgoat69's Avatar
Take a look at the 65 Lemans being done right now. I have a Magnacharged LQ4 in my 69. A few others have used Magnachargers as well.
