Crank sensor wiring extension
Does anyone know where I can buy a harness extension for the crank sensor on these LS engines? Or even the female connector end and pins so I can make my own? I found the map sensor extensions without too much trouble, but I'm having no luck with the crank sensor.
LS1Tech Sponsor
I can make you one, just shoot me a pm or feel free to email me.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic241851_3.gif)
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
i had the same issue... my puppy chewed the wires right at the plug and there was no soldering it back together. my buddy works at a gmc dealer in town and he got me an assortment of all the different pin connectors gm ever used. he said he could get my the actual plug too if i needed. but thats a posibility for you checking with your local dealer.
